I have been designing a school project for the last 2 months using the student version of inventor 2014. The realistic views have been working the whole time before but now it is not working. I click on it, and it just switches back to shaded view. If I click on shadows, or reflections I get the following message.
"One or more visual effects in use are not supported by the current system graphics hardware. We strongly recommend running the Diagnostics check in applications option for detailed information.
Would you like to run hardware Diagnostics now?"
After selecting Yes I get the following,
"The graphics driver is fully certified.
Graphics Hardware Description: OpenGL \ Microsoft Corporation \ GDI Generic
Graphics driver file vga.dll is version 6.1.7600.16385
Using the GDI-Generic driver
The display is using 32-bit color
Click the OK button to place diagnostic information on the clipboard.
I hit OK and everything closes. This is left on my clipboard. (Pasted after my plea for help)
Please help fast, my project is due in 3 days and I need this to function properly again. I have no idea why it stopped working out of no where and it is very frustrating because my team mates need screenshots for our presentation!
Thank you.
This graphics driver is fully certified.
Inventor Version:
Build: 170, Release: 2014 RTM - Date: Thu 02/28/2013
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Assembly Bonus Tools
Simulation: Dynamic Simulation
Simulation: Frame Analysis
iCopy
System Information:
Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: Apple Inc.
System Model: MacBookPro10,1
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz (8 CPUs), ~2.6GHz
System Memory: 16384MB RAM
Page File: 1787MB used, 30791MB available
DirectX Version: DirectX 11
DxDiag Version: 6.01.7600.16385
Inventor Hardware Library Information:
HW Library Version = $Revision: #1 $
HW Library Date = $DateTime: 2013/01/15 11:05:45 $
Windows 7
Original driver information:
Graphics HW Vendor Supported for Autodesk Inventor: False
rating 0, optimization level 3
Optimization Level = 0
Options = 0
Warning Options = 0
Hardware Library 2.0\Microsoft Corporation\GDI Generic
Settings for optimized and conservative:
SwapType: 3, 3
Workarounds: 0x01000206, 0x01000206
Workarounds2: 0x00000000, 0x00000000
Text Options: 0x00000000, 0x00000000
OpenGL Version: 11, 11
Recommended Optimization Level: 2
Texture Font Precision: 32
Driver Rating: 3
Inventor Version Tested: legacy
Using OpenGL 1.1
swap behavior: swapExchange(3)
OpenGL errors: None.
GL_EXTENSIONS: GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
Pixel Format = 7
Bits per pixel: Color 32, Depth 32, Stencil 8
GL_MAX_VIEWPORT_DIMS = 16384 x 16384
GL_MAX_TEXTURE_SIZE = 1024
Graphics driver log information:
Jun/25/2013-22:31:36: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Failed to create a device from the adapter.
Jun/25/2013-22:31:36: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jun/26/2013-02:19:48: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jun/26/2013-02:19:48: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jun/26/2013-03:58:49: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jun/26/2013-03:58:49: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jun/26/2013-07:41:22: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jun/26/2013-07:41:22: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jun/27/2013-00:21:54: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jun/27/2013-00:21:54: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jun/28/2013-01:08:16: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jun/28/2013-01:08:16: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/04/2013-23:47:41: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/04/2013-23:47:41: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/05/2013-02:42:12: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/05/2013-02:42:12: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/05/2013-04:56:35: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/05/2013-04:56:35: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/05/2013-07:05:55: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/05/2013-07:05:55: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/05/2013-10:01:01: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/05/2013-10:01:01: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/07/2013-15:48:00: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/07/2013-15:48:00: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/07/2013-23:19:19: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/07/2013-23:19:19: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/08/2013-01:01:57: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/08/2013-01:01:57: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/08/2013-01:06:17: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/08/2013-01:06:17: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/09/2013-07:38:10: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/09/2013-07:38:10: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/09/2013-01:01:53: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/09/2013-01:01:53: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/09/2013-07:18:44: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/09/2013-07:18:44: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/09/2013-13:04:52: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/09/2013-13:04:52: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/10/2013-18:35:09: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/10/2013-18:35:09: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/11/2013-11:23:43: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/11/2013-11:23:43: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/16/2013-05:19:39: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/16/2013-05:19:40: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/16/2013-10:46:15: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/16/2013-10:46:15: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/16/2013-18:33:28: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/16/2013-18:33:28: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/17/2013-05:14:06: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/17/2013-05:14:06: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/18/2013-03:07:53: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/18/2013-03:07:53: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/24/2013-05:51:57: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/24/2013-05:51:57: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/30/2013-12:44:29: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/30/2013-12:44:29: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/30/2013-12:59:06: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/30/2013-12:59:06: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/30/2013-20:34:51: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/30/2013-20:34:51: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/31/2013-06:11:14: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/31/2013-06:11:14: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/31/2013-06:25:24: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/31/2013-06:25:24: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/31/2013-10:44:23: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/31/2013-10:44:23: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/31/2013-12:19:05: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/31/2013-12:19:06: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Aug/01/2013-01:36:51: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Aug/01/2013-01:36:51: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Aug/01/2013-02:01:04: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Aug/01/2013-02:01:04: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Aug/01/2013-02:25:43: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Aug/01/2013-02:25:43: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Jul/31/2013-20:03:54: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/31/2013-20:03:54: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Aug/02/2013-06:40:12: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Aug/02/2013-06:40:12: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
Aug/02/2013-00:00:58: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Aug/02/2013-00:00:58: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
There is some problem when enumerating the adapters. Direct3d 10 factory initialization failed.
Aug/02/2013-00:03:56: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Aug/02/2013-00:03:56: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
Aug/02/2013-00:08:16: User changes the graphics driver manually: OpenGL -> D3D11.
Aug/02/2013-00:08:26: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Aug/02/2013-00:08:26: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
Aug/02/2013-00:08:26: User changes the graphics driver manually: OpenGL -> D3D11.
Aug/02/2013-00:08:31: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Aug/02/2013-00:08:31: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
Maybe some more information will help. I'm running through bootcamp and it has been working fine for the past two months or so. I've been looking around for similar errors and haven't seen any.
I didn't change any settings that I know of that may have caused this problem.
Also- it doesn't work for ANY models, or assemblies.
I started playing around with some of the hardware settings now (I read some other posts on the forums, but can't figure it out!)
Any help will be much apprieciated.
Did some more research and it looks as though its got something to do with my graphics card. Quite strange because I didn't change any hardware or anything 😕
Why do you need Realistic view to complete a project?
I prefer to work in Shaded with Edges mode and then go to
Enviroments>Inventor Studio and Render images.
The CADWhisperer YouTube Channel
You're correct, and typically when I am doing the design work I use shaded edges because the render time is very low and you can move things around freely. However I was trying to switch it over to get higher resolution pictures to show our professor and put in the presentation. I wanted it to look not just good but really good, you know for brownie points.
It is a team based project and he let us choose which modeling software we would like to use. I actually was trying to highlight inventor's strong/easy rendering capability. Most of the other students are using ProE or Catia, but I used inventor at an engineering firm I interned at a few semesters ago (on their computers). The modeling itself was quite easy because of my familiarity with the software, however this error that I have been getting is new to me. This has kind of nipped me in the butt to say the least, because all the models I was showing him before had realisitic quality and now they do not. Our team had the highest quality models before (mainly due to the lack of the other student's knowledge about their chosen programs) but now its about the same.
I still have yet to resolve the realistic viewing error, and it is quite annoying not being able to use inventor to its fullest capacity so if you have any advice, or information about how to fix the error I'd very much appreciate it.
This is an issue with the 2014 rendering kernal. AD are well aware of it:
