Inventor Forum
Inventor 2014 quick acces: Create new files according to my own custom template?
2 REPLIES 2
239 Views, 2 Replies
I created my own templates for Inventor, and I can acces them via the create new file in the regular menu, but as soon as I try to  use the quick acces toolbar to create a new file, it doesn't load my template automatically. Is there a way to do this?
2 REPLIES 2
yannicknielsen
Are your templates in the templates folder?
And do your Application Options show the path to that same folder?
The quick access menu will access the templates named "Standard.xxx" in the folder, so your templates need to be named that as well (unless there is a workaround of which I'm not aware)
See attached for an example
Product Design Suite Ultimate 2021
in reply to: yannicknielsen
I found the problem. I named my standards: Standard (mm).XXX, just as the files were named in the subfolders.
Thanks!
