Solved by Hochenauer. Go to Solution.
can you post an example ipt ...
it sounds like the setting to just display the centermark as an "alternate Representation" for the Punch is turned on.
If you right click on the flat pattern browser node, you can select "Edit Flatpattern Definition".
In there is a combo box to select the way punches are shown.
Please let me know if this solves the problem.
Gerald
It must have been saved in your sheetmetal template.
The default behavior is set in the sheetmetal Defaults->Sheetmetal Rule.
It is on the first tab (Sheet) at the bottom "Flat Pattern Punch Representation".
regards,
Gerald
