Inventor Forum
Inventor 2014 problems with windows 8.1 Continue
6 REPLIES 6
g_petkov
2969 Views, 6 Replies
SP1 made Inventor able to start on windows 8.1, but saving drawings in AutoCAD format is impossible. The "options" button does nothing and the "OK" button pressing results inevitably in a "Problems encountered while saving the document" error regardless of the target folder chosen or the file size.
OS: Windows 8.1 x64
6 REPLIES 6
mcgyvr
in reply to: g_petkov
Oh.. you expected it to work the first time? ha ha ha ha sucker.
It has been PROVEN that Autodesk can't get anything 100% function the first time around.
Someone over there has been reading too many "continuous improvement" books.
dgorsman
in reply to: mcgyvr
Because all of us *never* make mistakes.  Right?
mcgyvr
in reply to: dgorsman
I don't.. I'm perfect Smiley Very Happy
I only make mistakes so people don't catch on that I'm a cyborg.
g_petkov
in reply to: mcgyvr
I must add, that this bug applies not only to AutoCAD DWG export; as a matter of fact NO VECTOR EXPORT is possible from an Inventor 2014 drawing on a Windows 8.1 OS.
samiharada
Would you be more specific about "NO VECTOR EXPORT is possible"?
Which file formats you are seeing a problem?
I believe I was able to export 2D drawing to PDF, DXF, and DXFx format.
BTW, I posted a possilbe workaround in the following post:
Please try and see if that works for you.
Thank you,
http://forums.autodesk.com/t5/Autodesk-Inventor-General/Inventor-2014-fails-to-export-to-DWG-on-Win-...
-Sami Harada
Inventor Framework QA
They hired ObamaCare programers 🙂
I ran into all sort of issues:
  1. Editing material
  2. Hole dialog
  3. etc.
Hopefully Inventor 2020 will fixes the issues 🙂
Environment: Windows 8.1 Ultimate x64, Inventor 2014 Pro, SP1 with Update 1
