I have a problem with Inventor pro 2014, whereas it has recently gotten unbearably slow all of a sudden.
It will hang for anywhere between 5 seconds and 2-3 minutes whenever I right click a part in an assembly, whenever I try to run a New or Save and Replace command, whenever I try and move an unconstrained part in an assembly. Basically, it'll hang just about everytime I try and do something with it. The rest of the computer remains responsive and snappy while Inventor chugs away d
I have so far taken the steps to install SP1, hoping it would fix the issue. It stopped doing it for a day or two, then went right back to being slow as heck.
I checked my graphics card driver and saw that it was not certified with Inventor, so I downloaded and installed the correct one. That fixed the issue for another day or two then it came right back.
My IT department has run every test imaginable on my computer and came up with nothing. I'm guessing they are right seeing as the rest of the computer functions perfectly well.
I'm at my wits end, this is costing me precious time, for every 30 second operation I'm losing up to 3 minutes watching the program hang.
Am I the only one having this problem?
Computer specs:
i7-2600 @ 3.4Ghz
16GB RAM
Windows 7 Professional 64-bit
nVidia Quadro FX3800 running on 307.45 driver downloaded off this very website.
Hi! I still think it could be faceting related. There is one more thing you could try. Go to Tools -> Application Options -> File -> turn off "Enable Quick File Open" at the bottom of the dialog -> OK.
When this option is on, Inventor could cache the document in the memory. If somehow it requires to write to disk memory, it could slow down.
Thanks!
Johnson,
Sorry for the delay but your suggestion didn't solved the problem.
Sorry. It was a long thread so I only skimmed over the first two pages and thought I'd post since I've had so much trouble recently. Anywho, hope you solve your problem.
Hi! Eric,
I am very sorry to hear the issue is not yet resolved. So far the behavior seems to point to graphics issue. You are on Inventor R2014. Can you check and see if Express mode is turned on (Tools -> Application Options -> Assembly -> go to the bottom -> "Enable Express mode")? If it is checked, uncheck it and see if it makes a difference.
Many thanks!
The problem is still intermittent. I don't know why but sometimes, Inventor becomes slow. Very slow. I need to close my Inventor and restart it to have it run normally.
Today I can have it running normally (fluid graphical display with 3D mouse) with an assembly like 50168 occurences and 2945 open documents (10.3 Go RAM used by Inventor) in my session and yesterday the same assembly with only 30000 occurences and 2000 documents (6.5 Go RAM used by Inventor) turned slow all of a sudden. I had to shut down Inventor and restart it.
I can't send my files. Is it possible to contact someone with Autodesk when it happens to have him look at my Inventor session live?
