Inventor Forum
Inventor 2014 Placing Nuts and Bolts
2 REPLIES 2
danielw88
5586 Views, 2 Replies
We just upgraded from Inventor 2012 to 2014. When placing nuts and bolts in an assembly in 2012, you were able to select a hole and it would automatically size the bolt to the correct diameter. You could also select if you wanted it to fill in all holes of that size, on a face, with the bolt or you could just place one component.
I do not remember if it is just a setting that allows it that i can't find or if it is a bug and the drop function is not working properly, but could anyone give me some insight into this and if there is anything special that i need to do?
Thanks.
2 REPLIES 2
rhasell
in reply to: danielw88
Hi
Are you not thinking of Autodrop?
Reg
2024.2
Please Accept as a solution / Kudos
danielw88
in reply to: rhasell
Yup. That'd be it. Thanks a bunch.
