Greetings,
I have been using Inventor 2014 for a few weeks now with no real issues. Earlier last week I ran into a problem where I try to open a file from Vault, normally a Vault file browser window would open and I can check out a file, but for some reason that particular window is not showing causing my Inventor to lock up. If i do Alt-F4 I am able to access Inventor again but I am still unable to checkout any files. I have also gone through most of the options on the prompts and tried all sorts of combinations to either surpass that initial window or to have it show up again but nothing has worked. If anyone has any ideas I appreciate it.
I am unsure about the patches. Is there a way I can check to see if Im matching or missmatching?
Looks like I fixed it. I had Switched around my Display settings and the window was opening off the screen. So if anyone else has a simular problem do Alt-Space - hit "m" this will allow the active window to be moved and use the arrow keys to move the screen so that you are able to see it again. Also if you are using an nVidia card, right click and go into the nView Desktop manager, and under the windows manager section check the box that prevents windows from opening off-screen. This will prevent most future issues.
Thank you for all the help
