Greetings everyone,
here's my specs:
Alienware Aurora R4 - I7-4820K - 16gb RAM
Nvidia GTX 780 - 256gb SSD
I know that the GeForce series aren't "certified" by Autodesk, but still, why would Inventor keeps switching to compatibility mode? I had the same problem with my older computer, with a Quadro 3800.
How can I modify my settings so It stop switching from Quality to compatibility, it's getting pretty annoying.
G. Thibeault
OS?
Nvidia driver version?
Is Inventor crashing?
Have you installed all hotfixes/servicepacks?
Do you have proper permissions? (are you an admin on that computer?)
Does it always do it? or just sometimes?
Have you tried logging in as a different admin user?
OS: Windows 7 Professional 64 bit
Nvidia drivers: 337.88 (up to date via GeForce experience)
all service packs has been installed.
I have all needed permissions
It happens like 1/3 of the time
Although other users logged in, it happened too.
Greetings,
I'm admin on this computer, and was admin on the older comp. Can I manually changed the value in the registry via Regedit?
One thing that is not mentioned in this thread is the Graphic care must be Direct X compatable for the version of Direct X Inventor uses. If the card is not the only mode it able is compatiblity. Check with the manufacture and there specification to see if the card is Direct X complyent and for what versions.
The system spec's for Inventor 2014 are Direct3D 9 (Direct3D 11 or highter recommended).
Here is a report created by the NVIDIA control panel:
[Display]
Operating System: Windows 7 Professional, 64-bit (Service Pack 1)
DirectX version: 11.0
GPU processor: GeForce GTX 780
Driver version: 337.88
Direct3D API version: 11
Direct3D feature level: 11_0
CUDA Cores: 2304
Core clock: 862 MHz
Memory data rate: 6008 MHz
Memory interface: 384-bit
Memory bandwidth: 288.38 GB/s
Total available graphics memory: 10967 MB
Dedicated video memory: 3072 MB GDDR5
System video memory: 0 MB
Shared system memory: 7895 MB
Video BIOS version: 80.10.37.00.05
I'm pretty sure that my graphic card isn't the issue here...
I had hope for a bit, but then, as you can see in the attached picture, the only display adapter I have is the GTX 780....
Have you tried to shutdown and restart inventor after changing the hardware option to Quality mode?
Although it is enough for changing hardware option with all documents closed, sometimes it still doesn't work until restart inventor.
-Lisa
Greetings,
I've tried way too many times to restart Inventor, computer, you named it. It always keeps getting back at compatibility mode.
I also checked every options inside my Nvidia control panel, and there's no option for switching graphic cards.
Thru the Manage 3D settings tab, I went to the program settings, added Inventor.exe and then boost everything possible. Same thing happened...
In attachment, you can see the Nvidia control panel with the available options on the left.
Cheers,
G. Thibeault
Can you check whether d3dx11_43.dll, d3dx10_43.dll, d3dx9_43.dll exist in C:\Windows\System32 folder?
If not, please reinstall the DirectX installer from Inventor Setup\3rdParty\DirectX.
If yes, please check whether below files exist in Inventor bin folder C:\Program Files\Autodesk\Inventor 2014\Bin:
OGSBridge.dll
OGSFactory.dll
OGSArchive-4_0.dll
OGSATILIntegration-4_0.dll
OGSDeviceDiag-4_0.dll
OGSDeviceDX10-4_0.dll
OGSDeviceDX11-4_0.dll
OGSDeviceDX9-4_0.dll
OGSDeviceNull-4_0.dll
OGSDevices-4_0.dll
OGSFBXAssetTranslator-4_0.dll
OGSGDIFontDevice-4_0.dll
OGSGraphics-4_0.dll
OGSIOIntegration-4_0.dll
OGSObjects-4_0.dll
OGSProtein-4_0.dll
OGSRapidRT-4_0.dll
OGSRapidRTShaderInterface-4_0.dll
OGSRapidRTShaders-4_0.dll
OGSFragmentsLibrary-4_0.ogsf
tbbmalloc.dll
tbb.dll
If not, you may need reinstall Inventor to get these files back.
-Lisa
Greetings Lisa,
I've searched each items that you pointed out, one by one. Everything is there.
You could change the hardware options through below registry, please have a try and let me know whether it works.
Before doing that, make sure Inventor is closed.
[HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0\System\Preferences\Driver]
"Hardware Driver Type"=dword:00000103
"Optimization Level"=dword:00003333
After Inventor start, new a document and get the Inventor Diagnostics from Application Options->Hardware->Diagnostics, copy and paste the information here if it still doesn't work.
-Lisa
Hi Lisa,
I've made the changes into the Registry, restarted the computer and Inventor, and still have the same issue. I've attached the
diagnostic file.
Hope it gives you a good clue!
Ghislain
Hi Ghislain,
From your attached diagnostics, actually the Performance mode has taken effect already. But you still see the Hardware option is "Compatibility" in UI?
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
NVIDIA GeForce GTX 780
AIRViz Device Manager \ VirtualDeviceDx11
Feature Level 5_0
Performance Mode
Hardware Renderer
-Lisa
Good morning Lisa,
Here is a new diagnostic that I run this morning. I haven't reboot my computer and yet, it still gets to compatibility.
Greetings everyone.
At last, the problem as been corrected!
IT gave me access to read/write into the C:\program files\Autodesk, and voilà!
Thanks to all of you who took the time to check it out.
cheers,
Ghislain
