Inventor Forum
Inventor 2014, inserted excel file will not print in pdf
4 REPLIES 4
357 Views, 4 Replies
I have inserted an excel file into an Inventor idw, when trying to create a pdf file the excel image does not show in the pdf.  Any thoughts?!?
4 REPLIES 4
blair
Does it print to a standard Windows Printer, if so, then look at your PDF settings, change Quality settings from Standard to High Quality. Does it show if you use the Export to PDF function within Inventor as well?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Curtis_Waguespack
Hi mike.roberson,
I fairly certain this hotfix will resolve this issue for you, but post back if it doesn't:
http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/hotfix-inv1...
I hope this helps.
Curtis
in reply to: blair
I am using the Export to PDF function inside of Inventor.  However I changed the way I inserted the Excel file to that of a table.  Then I was able to print with everthing visible.  Thanks for your suggestion.
in reply to: Curtis_Waguespack
I did not try the hotfix.  I do not have full control of my computer.  The IT department has it restricted for loaded such items.  Thanks for the suggestion.
