I have inserted an excel file into an Inventor idw, when trying to create a pdf file the excel image does not show in the pdf. Any thoughts?!?
Does it print to a standard Windows Printer, if so, then look at your PDF settings, change Quality settings from Standard to High Quality. Does it show if you use the Export to PDF function within Inventor as well?
Hi mike.roberson,
I fairly certain this hotfix will resolve this issue for you, but post back if it doesn't:
I hope this helps.
Curtis
I am using the Export to PDF function inside of Inventor. However I changed the way I inserted the Excel file to that of a table. Then I was able to print with everthing visible. Thanks for your suggestion.
I did not try the hotfix. I do not have full control of my computer. The IT department has it restricted for loaded such items. Thanks for the suggestion.
