I just re-installed Inventor 2014 on my computer and wanted to share this with the community.
Goto your Tools menu.
Select Application Options.
Click on the Display tab.
Under 3d Navigation section (very bottom), click the checkbox for Reverse Direction.
Hi rkirk77,
Thanks for sharing this tip with the community. I'm sure someone will search and find your post in the future and be quite pleased that you took the time to post.
As an added tip, if you'd prefer to set AutoCAD to match Inventor's default, you can use setting described at this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8221121&linkID=9240817
I hope this helps.
Curtis
