Hi All,
I am currently trying to learn how to use the frame generator. Unfortunately after setting up a simulation and click "simulate" I get the following error " Solver: Failed to Connect to Solver"
Has anyone encountered this issue before? I already read the topic: solver solution
I did a quick forum search and found some references to an unregistered Kernel 23 but i didn't find that folder or similar in my registry.
Any and all help is appreciated
I don't understand.
Frame Generator and Frame Analysis are two different things.
You must create a frame before running simulation.
Does it work when going through the Tutorial example?
What version of Windows do you have.
Did you install Inventor with anti-virus and UAC disabled?
Have you installed Service Pack1 and Update 3?
@Anonymous wrote:
UAC disabled,why?
Because that is what works.
See this page about half way down
http://knowledge.autodesk.com/support-topics/483/3321#PrepareSystem
