Inventor General Discussion
New Member
geeksqd94
Message 1 of 20 (6,135 Views)
Inventor 2014 fails to export to DWG on Win 8.1
6135 Views, 19 Replies
10-02-2013 09:55 PM
I installed inventor 2014 on my laptop with windows 8.1, and export to DWG does not work. When i go to export, the options button doesnt work. when i click save, it pops up a windows and says "Problems encountered while saving the document." On my desktop with 2014 it works perfectly. I have the newest sp1. Does anybody know how to fix this and make this actually work.
Would you mind trying the following step and see if this fixes your issue?
1) Press [Windows] key to open the Windows' start page
2) Type "cmd" to find "Command Prompt" > right mouse click on it
  > select "Run as administrator"
3) On "Administrator: Command Proompt" window, type
  cd "c:\program files\autodesk\Inventor 2014\bin"
then
   inventor /install
4) Wait for 1 min (inventor will be executed background then exit silently)
Hope this helps,
-Sami Harada
Inventor Framework QA
mcgyvr
Message 2 of 20 (6,107 Views)
Re: Inventor 2014 fails to export to DWG on Win 8.1
10-03-2013 04:00 AM in reply to: geeksqd94
The fix is to wait for Autodesk to release an update..
Timeframe = unknown
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Employee
samiharada
Message 3 of 20 (6,086 Views)
10-03-2013 01:16 PM in reply to: geeksqd94
Thank you for reporting issue.
We confirmed the behavior you described, and logged this issue as DID 1506731
Best,
-Sami Harada
Employee
samiharada
Message 4 of 20 (6,062 Views)
10-09-2013 01:14 PM in reply to: geeksqd94
then
   inventor /install
Hope this helps,
-Sami Harada
New Member
geeksqd94
Message 5 of 20 (6,040 Views)
10-09-2013 02:05 PM in reply to: samiharada
Yes that does fix it.
Thanks you. It helps alot.
Member
ross.bateup
Message 6 of 20 (6,030 Views)
10-09-2013 02:16 PM in reply to: samiharada
Thx Sami
Don't know what that did but it works down with cut and paste and inserting autocad drawing
Ross
g_petkov
Message 7 of 20 (5,979 Views)
10-12-2013 10:23 PM in reply to: ross.bateup
Yes. This solves the problem. Thanks!
Active Contributor
bgarden
Message 8 of 20 (5,559 Views)
11-15-2013 10:13 AM in reply to: samiharada
Just wanted to add: this issue is not only for Windows 8.1 .  We have also seen this with Windows 7 and the same solution applies.
New Member
utahtransplant
Message 9 of 20 (5,115 Views)
12-23-2013 01:39 PM in reply to: geeksqd94
this did not solve my problem my system still cannot export a drawing file or any other kind of file
New Member
smarlb3
Message 10 of 20 (4,676 Views)
01-27-2014 08:17 AM in reply to: samiharada
Fixed my problem of importing dwg files into inventor.  Now I can see them.  But the 2d to 3d converter is not recognizing the file.  At least one more step on the road.
