Inventor Forum
Inventor 2014 fails to export to DWG on Win 8.1
23 REPLIES 23
Message 1 of 24
geeksqd94
16539 Views, 23 Replies
I installed inventor 2014 on my laptop with windows 8.1, and export to DWG does not work. When i go to export, the options button doesnt work. when i click save, it pops up a windows and says "Problems encountered while saving the document." On my desktop with 2014 it works perfectly. I have the newest sp1. Does anybody know how to fix this and make this actually work.
23 REPLIES 23
Message 2 of 24
mcgyvr
in reply to: geeksqd94
The fix is to wait for Autodesk to release an update..
Timeframe = unknown
Message 3 of 24
samiharada
Thank you for reporting issue.
We confirmed the behavior you described, and logged this issue as DID 1506731
Best,
-Sami Harada
Inventor Framework QA
Message 4 of 24
samiharada
Would you mind trying the following step and see if this fixes your issue?
1) Press [Windows] key to open the Windows' start page
2) Type "cmd" to find "Command Prompt" > right mouse click on it
  > select "Run as administrator"
3) On "Administrator: Command Proompt" window, type
  cd "c:\program files\autodesk\Inventor 2014\bin"
then
   inventor /install
4) Wait for 1 min (inventor will be executed background then exit silently)
Hope this helps,
-Sami Harada
Message 5 of 24
geeksqd94
in reply to: samiharada
Yes that does fix it.
Thanks you. It helps alot.
Message 6 of 24
ross.bateup
Thx Sami
Don't know what that did but it works down with cut and paste and inserting autocad drawing
Ross
Message 7 of 24
g_petkov
in reply to: ross.bateup
Yes. This solves the problem. Thanks!
Message 8 of 24
bgarden
Just wanted to add: this issue is not only for Windows 8.1 .  We have also seen this with Windows 7 and the same solution applies.
Message 9 of 24
utahtransplant
this did not solve my problem my system still cannot export a drawing file or any other kind of file
Message 10 of 24
smarlb3
Fixed my problem of importing dwg files into inventor.  Now I can see them.  But the 2d to 3d converter is not recognizing the file.  At least one more step on the road.
Message 11 of 24
keironcalder
I have a student licence of Inventor 2014.
I tried the command fix but I get a message saying "inventor" is not recognised as an internal or external command.
To further complicate things I am running windows 8.1 as a virtual drive on Parallels.
Is their anything else I can do to fix this issue?
Message 12 of 24
luke.burkey
Thanks for the description. However, I'm having an issue with  command prompt. Affter running administrator I get this response after running "c:\program files\autodesk\Inventor 2014\bin":
"'c:\pogram' is not recognized as an internal or external command, operable program or batch file."
I desperately need to get these DWG files redy for a project. I have also atatched an image describing the issue.
Message 13 of 24
matteo.tognin
Message 14 of 24
matteo.tognin
in reply to: luke.burkey
Hi luke.burkey, you must use the symbol " at the beginning and end of the path. Example:
"C:\Program Files\Autodesk\Inventor 2014\Bin\inventor.exe" /install
Message 15 of 24
tpascual
Great !!!!
Message 16 of 24
podajdlugopis
That worked on my 8.1 x64 Windows 🙂 AMAZING!!!!!!!!! Thank you very much!!!!!
Message 17 of 24
mertcansagir
It didn't help to me ı should import today it an emergence situation pls help
Message 18 of 24
spascual
Hi Sir,
Problaly you must switch off antiviruses program and UAC and then execute line above
Message 19 of 24
Godzilla967
I have an ASUA laptop with windows 8.1 and can not run Inventor 2014. It keeps giving error 000142. Please any idea on what to do?
Message 20 of 24
blair
in reply to: Godzilla967
Make sure that you have installed all the SP's and Updates. Link is at the bottom of this page.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
