Inventor Forum
Inventor 2014 Error 0xC0000142 on Windows 8
130 REPLIES 130
Message 1 of 131
117618 Views, 130 Replies
I have uninstalled and reinstalled Inventor 2014 5 or 6 times and I am still recieving the error code 0xC0000142 upon start up.  I also have AutoCAD installed, which starts up fine.
Error Log:
<System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2013-08-06T04:17:38.000000000Z" />
  <EventRecordID>57992</EventRecordID>
  <Channel>Application</Channel>
  <Computer>Andrew-PC</Computer>
  <Security />
  </System>
<EventData>
  <Data>Inventor.exe</Data>
  <Data>18.0.17000.0</Data>
  <Data>512fe9d7</Data>
  <Data>KERNELBASE.dll</Data>
  <Data>6.3.9431.0</Data>
  <Data>51bd0a54</Data>
  <Data>e06d7363</Data>
  <Data>0000000000006aac</Data>
  <Data>217c</Data>
  <Data>01ce925be255dd0e</Data>
  <Data>D:\Files\Programs\Autodesk\Inventor 2014\Bin\Inventor.exe</Data>
  <Data>C:\WINDOWS\system32\KERNELBASE.dll</Data>
  <Data>20365b99-fe4f-11e2-befd-3085a9991555</Data>
  <Data />
  <Data />
  </EventData>
130 REPLIES 130
Message 81 of 131
roblawarre
in reply to: roblawarre
2014 Inventor LT SP1 fixed my installand got past the 0xC0000142 error.  Had difficult time with Internet Explorer because it was unstable and crashed several times. Once the SP was installed I was able to register my serial number and launch the Inventor LT. Launching AutoCAD 2014 LT has not been an issue.  Have not used Inventor enough to tell if there are any other issues.
Message 82 of 131
Praise Jesus! I did the same thing, installing and uninstalling the program 4 times.... Thank you for the solution.
Message 83 of 131
Message 84 of 131
tsg2437
Thanks! I have 8.1 and am using Autodesk CAD2014 no probs, tried opening Autodesk Inventor 2014 and received 0xC0000142 error. SP1 fixed it!
Message 85 of 131
in reply to: tsg2437
where and how do I get sp1 patch and fix the problem error code oxc0000142
on windows 8.1? thank you and much appreciated. Thank you!
Sincerely John R.D. Kuck
Cell (847) 693-9982
Message 86 of 131
ChrisMitchell01
1.     Install 2014 SP1 –http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
2.     Install 2014 SP1, Update2 -http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22744369&linkID=9242019
Ensure you follow the steps here, after you install the update:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22238097&linkID=9242018
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 87 of 131
You know what? There too many choices for me to try and make this work. Verdict: Uninstalling.
Message 88 of 131
I'm trying to install and run the free student version of Autodesk Inventor Professional 2014 - WIN 64 - EN. It seemed to install but when i run it i too get the windows 8.1 error message:The application was unable to start correctly (0xc0000142). I've then tried to update using the service pack that fixes this, but wheni run Inventor2014_SP1_x64.msp i get another error message about 90% through its installation (attached): Installation ended prematurely because of an error, and it doesn't install it. Help?!?
My specs:
Operating System
    Windows 8.1 64-bit
CPU
    Intel Core i7 4770 @ 3.40GHz
RAM
    16.0GB Dual-Channel DDR3 @ 818MHz (11-11-11-28)
Motherboard
    Dell Inc. 0KWVT8 (CPU 1)
Graphics
    2048MB ATI AMD Radeon R9 270 (ATI)
Message 89 of 131
aj17atj
I just downloaded Autodesk Invento 2014 as of last night. February 25th, 2014. I thought everything was fine until this morning when i went to open the program. It will not open, I am using windows 8.1. What do i do?
Message 90 of 131
jessica.t
in reply to: aj17atj
Hi Andrew and welcome to the Autodesk Community!
Did you try the solution in the post above? Please let me if that makes a difference. Thank you!
Jessica Thrasher
Message 91 of 131
aj17atj
in reply to: jessica.t
I am unsure how to download that extra part?
Message 92 of 131
blair
I was goint to post the link but since you are a student, you might as well learn. At the bottom of this web page is a colum labeled Help & Support. Directly below this column is the phrase and link "Service packs & updates". This will then take you to a web page that you can then select the ADSK product you require updating.
Delta Tau Chi ΔΤΧ
Message 93 of 131
Any thoughts on my issue?
Message 94 of 131
andreasahn
in reply to: sam_m
It din't work
Message 95 of 131
Make sure that Inventor is not shown as installed on your system: Control Panel>Programs and Features. If so you will need to use the Autodesk Un-Install Tool to remove the software or just use the Windows Uninstall. Make sure that you are logged in as Administrator to re-install the software. I would make sure that all Anti-Virus software is disabled. Possibly you were only logged in with normal user rights and not Admin rights.
Delta Tau Chi ΔΤΧ
Message 96 of 131
stuart1289
in reply to: iSolarexchange
Hi Chris, I am running inventor 2012 LT and i have the same error as above. I see you mention that the hotfix will be availble soon for 2012 LT, is it available yet please? Thanks, Stu
Message 97 of 131
Stu,
We don't officially support LT2012 on win8.1 - however you "should" be able to use the fixed rse.dll file for full Inventor 2012. I'll send you that off-line.
-Chris
Chris Mitchell
Autodesk, Inc.
Message 98 of 131
stuart1289
Morning Chris,
Fair play mate you're a legend!! Worked a treat! I now have inventor LT 2012 working on windows 8.1! Some said it couldn't be done and I was beginning to think it wouldn't be possible but you pulled it out of the bag!! Cheers mate much appreciated!!
Cheers, Stu
Message 99 of 131
Thanks for that Stu,
Legend in my own lunchtime perhaps Smiley Happy Sorry this was so arduous for you.
-Chris
Chris Mitchell
Autodesk, Inc.
Message 100 of 131
stuart1289
No worries Chris, thank you!!
Ha ha! Problems happen mate it's how quick we can fix them that counts!! Thank you again!!
Stu
