I have uninstalled and reinstalled Inventor 2014 5 or 6 times and I am still recieving the error code 0xC0000142 upon start up. I also have AutoCAD installed, which starts up fine.
Error Log:
2014 Inventor LT SP1 fixed my installand got past the 0xC0000142 error. Had difficult time with Internet Explorer because it was unstable and crashed several times. Once the SP was installed I was able to register my serial number and launch the Inventor LT. Launching AutoCAD 2014 LT has not been an issue. Have not used Inventor enough to tell if there are any other issues.
Praise Jesus! I did the same thing, installing and uninstalling the program 4 times.... Thank you for the solution.
Thanks! I have 8.1 and am using Autodesk CAD2014 no probs, tried opening Autodesk Inventor 2014 and received 0xC0000142 error. SP1 fixed it!
I'm trying to install and run the free student version of Autodesk Inventor Professional 2014 - WIN 64 - EN. It seemed to install but when i run it i too get the windows 8.1 error message:The application was unable to start correctly (0xc0000142). I've then tried to update using the service pack that fixes this, but wheni run Inventor2014_SP1_x64.msp i get another error message about 90% through its installation (attached): Installation ended prematurely because of an error, and it doesn't install it. Help?!?
My specs:
Operating System
Windows 8.1 64-bit
CPU
Intel Core i7 4770 @ 3.40GHz
RAM
16.0GB Dual-Channel DDR3 @ 818MHz (11-11-11-28)
Motherboard
Dell Inc. 0KWVT8 (CPU 1)
Graphics
2048MB ATI AMD Radeon R9 270 (ATI)
I just downloaded Autodesk Invento 2014 as of last night. February 25th, 2014. I thought everything was fine until this morning when i went to open the program. It will not open, I am using windows 8.1. What do i do?
I was goint to post the link but since you are a student, you might as well learn. At the bottom of this web page is a colum labeled Help & Support. Directly below this column is the phrase and link "Service packs & updates". This will then take you to a web page that you can then select the ADSK product you require updating.
Hi Chris, I am running inventor 2012 LT and i have the same error as above. I see you mention that the hotfix will be availble soon for 2012 LT, is it available yet please? Thanks, Stu
Stu,
We don't officially support LT2012 on win8.1 - however you "should" be able to use the fixed rse.dll file for full Inventor 2012. I'll send you that off-line.
-Chris
Morning Chris,
Fair play mate you're a legend!! Worked a treat! I now have inventor LT 2012 working on windows 8.1! Some said it couldn't be done and I was beginning to think it wouldn't be possible but you pulled it out of the bag!! Cheers mate much appreciated!!
Cheers, Stu
Thanks for that Stu,
Legend in my own lunchtime perhaps Sorry this was so arduous for you.
-Chris
No worries Chris, thank you!!
Ha ha! Problems happen mate it's how quick we can fix them that counts!! Thank you again!!
Stu
