Inventor General Discussion
Active Member
roblawarre
Message 81 of 113 (2,303 Views)
Re: Inventor 2014 Error 0xC0000142 on Windows 8
12-18-2013 11:33 AM in reply to: roblawarre
2014 Inventor LT SP1 fixed my installand got past the 0xC0000142 error.  Had difficult time with Internet Explorer because it was unstable and crashed several times. Once the SP was installed I was able to register my serial number and launch the Inventor LT. Launching AutoCAD 2014 LT has not been an issue.  Have not used Inventor enough to tell if there are any other issues.
Member
gbjohnk
Message 82 of 113 (2,077 Views)
01-01-2014 10:42 PM in reply to: aslevins
Praise Jesus! I did the same thing, installing and uninstalling the program 4 times.... Thank you for the solution.
Member
gbjohnk
Message 83 of 113 (2,080 Views)
01-01-2014 10:47 PM in reply to: aslevins
New Member
tsg2437
Message 84 of 113 (1,747 Views)
01-15-2014 06:28 AM in reply to: aslevins
Thanks! I have 8.1 and am using Autodesk CAD2014 no probs, tried opening Autodesk Inventor 2014 and received 0xC0000142 error. SP1 fixed it!
Member
gbjohnk
Message 85 of 113 (1,729 Views)
01-15-2014 09:45 PM in reply to: tsg2437
where and how do I get sp1 patch and fix the problem error code oxc0000142
on windows 8.1? thank you and much appreciated. Thank you!
Sincerely John R.D. Kuck
Cell (847) 693-9982
Employee
ChrisMitchell01
Message 86 of 113 (1,721 Views)
01-15-2014 10:05 PM in reply to: gbjohnk
1.     Install 2014 SP1 –http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
2.     Install 2014 SP1, Update2 -http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22744369&linkID=9242019
Ensure you follow the steps here, after you install the update:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22238097&linkID=9242018
Chris
Chris Mitchell
Inventor Customer Engagement Team
New Member
t.shava
Message 87 of 113 (1,427 Views)
01-27-2014 05:42 AM in reply to: aslevins
You know what? There too many choices for me to try and make this work. Verdict: Uninstalling.
New Member
cameron.pickeringsmith
Message 88 of 113 (736 Views)
02-25-2014 09:21 PM in reply to: ChrisMitchell01
I'm trying to install and run the free student version of Autodesk Inventor Professional 2014 - WIN 64 - EN. It seemed to install but when i run it i too get the windows 8.1 error message:The application was unable to start correctly (0xc0000142). I've then tried to update using the service pack that fixes this, but wheni run Inventor2014_SP1_x64.msp i get another error message about 90% through its installation (attached): Installation ended prematurely because of an error, and it doesn't install it. Help?!?
My specs:
Operating System
    Windows 8.1 64-bit
CPU
    Intel Core i7 4770 @ 3.40GHz
RAM
    16.0GB Dual-Channel DDR3 @ 818MHz (11-11-11-28)
Motherboard
    Dell Inc. 0KWVT8 (CPU 1)
Graphics
    2048MB ATI AMD Radeon R9 270 (ATI)
New Member
aj17atj
Message 89 of 113 (694 Views)
02-26-2014 11:43 AM in reply to: aslevins
I just downloaded Autodesk Invento 2014 as of last night. February 25th, 2014. I thought everything was fine until this morning when i went to open the program. It will not open, I am using windows 8.1. What do i do?
jessica.t
Message 90 of 113 (686 Views)
02-26-2014 11:59 AM in reply to: aj17atj
Hi Andrew and welcome to the Autodesk Community!
Did you try the solution in the post above? Please let me if that makes a difference. Thank you!
Jessica Thrasher
