Inventor Forum
Inventor 2014 Error 0xC0000142 on Windows 8
130 REPLIES 130
Message 1 of 131
117619 Views, 130 Replies
I have uninstalled and reinstalled Inventor 2014 5 or 6 times and I am still recieving the error code 0xC0000142 upon start up.  I also have AutoCAD installed, which starts up fine.
Error Log:
<System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2013-08-06T04:17:38.000000000Z" />
  <EventRecordID>57992</EventRecordID>
  <Channel>Application</Channel>
  <Computer>Andrew-PC</Computer>
  <Security />
  </System>
<EventData>
  <Data>Inventor.exe</Data>
  <Data>18.0.17000.0</Data>
  <Data>512fe9d7</Data>
  <Data>KERNELBASE.dll</Data>
  <Data>6.3.9431.0</Data>
  <Data>51bd0a54</Data>
  <Data>e06d7363</Data>
  <Data>0000000000006aac</Data>
  <Data>217c</Data>
  <Data>01ce925be255dd0e</Data>
  <Data>D:\Files\Programs\Autodesk\Inventor 2014\Bin\Inventor.exe</Data>
  <Data>C:\WINDOWS\system32\KERNELBASE.dll</Data>
  <Data>20365b99-fe4f-11e2-befd-3085a9991555</Data>
  <Data />
  <Data />
  </EventData>
130 REPLIES 130
Message 41 of 131
Yes it's OK for the student version too. You didn't attach your image though so can't see the error.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 42 of 131
axg110130
I sent you the picture in your email. I couldn't attach it here because I'm using my Iphone now
Message 43 of 131
in reply to: ChrisMitchell01
thank you sooo much, you saved me hours of troubleshooting
Message 44 of 131
Hi
I have got AutoDesk Inventor 2014 student version and Win 8.1
Is it possible for us to install: Inventor 2014 SP1 Release Candidate Beta ?
If YES can you pleas post the link ?
Tags (1)
Message 45 of 131
Hi Chris
The link you have typed: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
I have tryed to install it but cloudn't, please see the attached picture!
What should I do ?
Message 46 of 131
chucksavatsky
Hi, Inventor 2014 SP1 has been released. The link to Inventor 2014 Pro SP1 is http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019 The link to Inventor 2014 SP1 is http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
Chuck Savatsky
Director Software Development Inventor
Message 47 of 131
Hello hosad13
I've ocassionally seen that error. Usually a reboot before installing the SP clears it. Did you hit the Retry button ? Are you running the SP1 install as administrator account ?
Chris
Chris Mitchell
Autodesk, Inc.
Message 48 of 131
For 2014, after installing SP1 if you still see an error, then the new dll files still need to be registered with the OS as Administrator
Open a command prompt (just type cmd in the windows “search” section & then Run as administrator. Then type:
Then, after about 1 minute, start Inventor.
Updates for 2012 & 2013 should be available next week. Again these can be made available before then if you contact me. (chris.mitchell@autodesk.com )
Hope this helps
Chris
Chris Mitchell
Autodesk, Inc.
Message 49 of 131
Hi Chris
Yes I'm running it as Admin. I have both reboot my pc and hit the retry button with no success. I get another Error: 1321 I don't understand it ?
Please see the attached picture.
Message 50 of 131
tranttina2
yes, to link
http://www.vn-zoom.com/f103/da-co-ban-fix-inventor-2014-cho-windows-8-1-a-2790704.html,
you will see
Autodesk Inventor 2014 SP1
X86
X64
it for you
Message 51 of 131
See http://forums.autodesk.com/t5/Inventor-General/Update-3-for-Inventor-2013-SP2-has-been-released/m-p/... for the latest on this issue for Inv 2013
Chris
Chris Mitchell
Autodesk, Inc.
Message 52 of 131
oscarlarrabure
Hey when is the SP patch coming up because I can't download the beta version because the release of the SP is iminent....how iminent? you hace a date?
Message 53 of 131
Inventor 2014 SP1 has been released.  The link to Inventor 2014 Pro SP1 is http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019The link to Inventor 2014 SP1 is http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
Chuck Savatsky
Message 54 of 131
In addition to 2014 SP1, fixes have also been released on the standard Data & Downloads site, for:
2011: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22541232&linkID=9242019
2012: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22506876&linkID=9242019
2013: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22436649&linkID=9242019
Note that there is a manual post-install step required. See TS22446139 for more info.
Chris
Chris Mitchell
Autodesk, Inc.
Message 55 of 131
isz9
in reply to: apf246
I'm having the same windows 8.1 issue with the 0xc0000142. Cann someone help.
Message 56 of 131
ChrisMitchell01
in reply to: isz9
Have you installed the update specific to your version of Inventor as mentioned below ?
Chris
Chris Mitchell
Autodesk, Inc.
Message 57 of 131
Yes, thanks 🙂
BR.
Hojat
Message 58 of 131
apf246
It's very good to hear there is a patch for inventor 2011. But I have a big problem, the patch is not working for AutoCAD® Inventor® Professional 2011 64-bit-edition (this version is not listed on the patch site, only AutoCAD® Inventor® Professional Suite 2011)
If I try to apply this patch I get an error message with something like programm not installed or other version.
Message 59 of 131
ChrisMitchell01
in reply to: apf246
The posted patch "should" work for any flavour of 2011. Ensure you have the latest Service Pack's installed for 2011 before installing the hotfix.
Chris
Chris Mitchell
Autodesk, Inc.
Message 60 of 131
apf246
You are right, it is working 🙂
But I didn't see that the service-packs are incremental...
After installing SP1 --> SP2 --> DL22541232 everything works perfectly well
