Hi everyone,
I use A1 sheet for creating drawings. As for A1 all line weights are set correctly. Since it is needed mentioned drawings are printed to A3 sheet. The problem is Inventor changes line weight so in result I have printed A1 drawing on A3 sheet which is "minimized" as I wanted but also "minimazed" to A3 are line weights. I want these line weights to stay as requested for A1.
How can I manage this?
Best regards,
EMM
Solved by blair. Go to Solution.
Welcome to the forum.
You have to create the needed line weights in the styles library. Than on each of these A1 and A3 sheets, change the specific line weights needed to these newly created line styles. Not to mention when you create them in the styles you need to save them to the library.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks for quick reply.
As far I cannot understand you. Please be more precise. I have added in Styles Editor Layers few more layers with line weights assigned. On drawing border and title block were assigned to those layers. Sheet size is A1, but I am printing it on A3, and I would like to have printed line weight like to like I set them in Layers. Please reconcile.
You need to go here to the styles and create a new layer style in each of the templates.
Are you saying you have done this already?
Cadmanto, yes ofcourse I did.
Blair, exactly, you caught what I am fighting with - seriosuly is there no option? Inventor seems to be so powerful...
Blair, thx, continuing, maybe you could also advise me how it is in Inventor when I want to scale font? Exactly RomanT. It doesnt get fatter if I change its lineweight. Why cant it works like to like Autocad?
Great thx Blair, I like to be clear with it.
As far you are smart with Inventor, maybe I could ask you to help me with this.
Please take a look at attached printscreen from drawing.
I would like to make user symbol of section symbol : green circled part have to be fixed, but red circled part should move on demended dimension V which is variable. I would like to insert this symbol on sheet and then (not in definition edit) change dimension V as required. The best would be just pick up with mouse red circled part and slip it off. Is it possible in Inventor?
Agree, thus these Standards are fixed I was asking about symbol only. Is action with variable dimension feasible?
