Hi All,
I have a question about CC parts. When we save a custom part out to a particular job, there's an issue sometimes wherby if the part gets subsequently renamed in Explorer, if i open the part up, the Browser Bar shows the orig CC name at the top, even tho the filenane shown in the top of the Inventor main window is correct, and if its called up in an assembly (the renamed part is relinked obviously) the name that appears in the Assy Browser Bar is the orig CC name as well, and not the new name. The only way i can seem to correct it is if i open the part and blank the name in the browser bar - when i hit return to exit, the correct filename appears, and when i go back into the assy that name is also updated correctly. But i cant figure out why i have to blank the name in the renamed part in order to get it to update. Hope that makes sense, can anyone shed some light on this please?
I've never run across this particular issue before because I use Vault and do any file renaming from there. But I've seen this discussed before, and I'm pretty sure that what you are seeing is not new, and the workaround you are using sounds like the correct one. What the browser shows is not necessarily the file name, but rather the "instance" name. That doesn not update automatically based on a file name change, but like you described, it will update if you blank it out in the browser. I wouldn't call it a bug,... maybe an inconvenience?
Check th Inventor Idea station, there may be an idea (or more than one) related to this. If so, you could add your kudos and any comments you have about it. If there isn't one, you could add one suggesting that this be dealt with in the future.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
