Hi everyone
I recently updated to Inventor Professional 2014.
The problem I encounter is that Inventor crashes sometimes when I turn the realistic view mode on.
Is there anyone else who has this problem?
Also the rendering in realistic view mode is much slower than with Inventor 2013.
Are there some ray tracing options that I need to set up?
Kind regards
Nick
Same here! I just upgraded to Product Design Suite Premium 2014 from Factory Design Suite 2013 and cannot render anything. Even on the lowest antialiasing setting. Crashes the program everytime!
No issues here...yet
Xi® MTower™ PCIe Workstation
Intel® Core™ i7 2700K @ 4.10GHz
16384MB DDR3 @1333MHz Dual Rank Interleave
nVidia® EVGA® GeForce® GTX 580 Classified 3072MB GDDR5
500GB 7200RPM SATA 6.0Gb/s 16MB Cache IntelliSeek™
Asus® P8P67 Motherboard
27" S27A350H ToC Samsung® SyncMaster™ Wide LED 2ms. 1920x1080
850W Corsair® TX Series Power Supply
Microsoft® Windows® 7 Professional Edition 64Bit SP1
You can use the NFO file to determing the video card and driver version you have installed. More than likely it is old.The system NFO file of that machine Start>All Programs>Accessories>System Tools>System Information. Under components there is Display. Compare that information against the below link.
Verify Hardware certification
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
If your card is not listed then it is not certified. Try getting the manufacturers latest and greatest one for that card.
Don
The rest of your system specs will help eliminate a number of possibilities.
