The proablem is when I try to edit a part within an assembly and I click on a face and choose new sketch (to modify the part), Inventor 2014 crashes! This happens every time I try to do it. This is a brand new installation and I am awaiting my authorization code. Could this have anythng to do with it?
Service Pack One had been installed prior to the problem. I could only find three updates for 2014 and I downloaded and installed them. The problem still exists. In fact the problem occurs in any assembly. Should I attach the .iam and .ipt using the attachment button? Also, if there is indeed a fourth update, where can I find it?
Ed
I just discovered something interesting. If I souble click on the part I want to modify in my assembly then right click somewhere off the part and choose new sketch and then click on the surface I want to sketch it doesn't crash. The original crashes occured when I opend the part, clicked on the surface I want to sketcch then chose new sketch from the glyph or whatever you call it that pops up.
Hi! Did you submit the crash report when it happens? If yes, please send me an email so I can look for the report.
Many thanks!
Here is my latest update after I forced a crash this morning. This is what I reported back to AutoDesk when prompted for a crash report.
Refer to CER's 94929347, 94930000 & 94777885. This is what is happening and I can repeat it anhytime I like:
1. In an assembly double click on a part.
2. Click on a face you want to sketch for a new featujre.
3. From the circular field of options that appears click new sketch.
4. Inventor crashes.
The work around that works everytime is:
2. Right click in space off the part.
3 Choose new sketch from the dorp down box NOT the circular field.
4.Click on surface you want to sketch.
5. Go on your merry way.
Hi! I have located the crash reports you submitted. This seems to be a known issue that the engineering team is trying to resolve. Could you send me an email (johnson.shiue@autodesk.com) and I would like to follow up with you with some specifics?
Many thanks!
My hat is off to AutoDesk! I got an email from them referencing the CER numbers regarding this issue and telling me that they were solved in Service Pack 2 which I downloaded and installed. I went through my crash routine and could not force the crash. Problem solved. Thank you again.
I started using Inventor with Release 5.0 and stopped upgrading after Release 2009. I went to 2014 only after my faithful XP machine went the way to the buffalo and I had to upgrade to a Windows 7 machine. The kind of service and support AutoDesk has thus far provided takes some of the hurt out of the sting the hardware and software upgrades gave my wallet. Thank you again AutoDesk.
Ed
