Inventor Forum
Inventor 2014 crashes at launch
5 REPLIES 5
Nechy
3251 Views, 5 Replies
my Problem is, that Inventor 2014 crashes directly after starting the .exe. I installed the Update 1, but nothing change. Even a reinstall (Format C: ) of Windows 8 didn't help. The first program after the windows updates was Inventor, but directly the crash. Last week it, works fine :(. When i read the .dmp ... it tells that a third party driver could cause the problem.
I hope someone can help.
5 REPLIES 5
pcrawley
in reply to: Nechy
Have a look through your system restore points.  Is there an update or driver installation that occured soon after the last time you were able to run Inventor?
Peter
Nicolas.Bourquin
in reply to: Nechy
Do you receive an error message after the launch of Inventor ?
If yes, maybe this link could help you:
http://usa.autodesk.com/getdoc/id=TS21825687
Could you confirm if the problem is the same when you create and use a new windows administrator profile ?
Hope that will help.
Nicolas Bourquin
Nechy
in reply to: pcrawley
Yeah i deinstall all updates. But that didnt help.
Yesterday i install Windows 7 x64  ... install Inventor 2014 ... the same crash. And yes i receive an error Message. And i get under the Serialnumber some F's.
So and i tried it with another admin profile ... the same crash at the beginning. Short time i see the Inventor frame but then  i get the error report.
Nechy
in reply to: Nechy
No one an idea ? 😕
Nechy
in reply to: Nechy
OK problem solved ... it was a nvidia update in the backround. So i didnt recognize it. -.-. The old driver works.
