We are having problems with some users trying to load inventor
you get the splash screen, the bar goes half way then it crashes out to the send report to autodesk screen.
The weird thing is if i log in as an admin it works ok, and some other users it works fine.
permissions, map drives all the same, Iv cleared out the profile for the problem user and it still happens.
The dump file says
<ProductInformation name="Autodesk Inventor" executable_name="" build_version="180170000 AIPSA" version_label="2014 Production Candidate" registry_version="2014" install_id_string="" registry_localeID="1033" license_type="Network" usage_type="Educational Institution Version" uptime="5876713671" current_session_length="1" session_start_count="12" session_clean_close_count="7"/>
<RuntimeInformation>
<Document active=""/>
<Uptime session="0.00:00:01.9500125" accumulated="0.00:09:47.6713671" crashes="5"/>
<Dump filename="Inventor130918100830.dmp">
<Commands last="" state="completed"/>
<Requests last="" state="completed"/>
<Exceptions>
<Exception code="0xC0000005" text="ACCESS_VIOLATION" address="0x000007FEF1999229" extraInfo="module:C:\Program Files\Autodesk\Inventor 2014\Bin\VbcSrv64.dll ">
<AccessViolation type="Read" address="0x0000000000000000" PGStatus="0x00000001" accessing_null_ptr="true"/>
</Exception>
