Hi guys,
I like to install the student version inventor 2014 in my (lenovo i7, win 8, 64 bit) laptop. After I downloaded the installation and try to run it , it shows a message by saying communication failure. I have attached the screen shot of that error message to this message. please help me with this.
it was due to a lost of connection or a internet interruption.
I suggest to use the option browse Download instead Install Now.
Admaiora
thanks for the tip but unfortunately it keeps on stopping to download after it downloads 150 MB .. even though I have almost 600 gb free space
Pay attention. With "browser download" there are 2 files to download.
Move the download windows, below will be the other download window.
Admaiora
Hi monjbrutal.v,
Please, disable your firewall and anti-virus programs prior to downloading and download your program from our Virtual Agent linked here (click on Download Links, select product and version).
As admaiora mentioned, if you are downloading the 64-bit version, you will need to download Parts 1 and 2 of the download.
I hope this helps!
No there are 4 options
1. Install now
2. download now
3. browser download
4. help me to decide
I treid download now but it says pending for long time.. Then I tried browser download it stops downloading after 150 mb as i said.. so which one you are suggesting.. thanks
Thanks for the tip .. but I could not find part 2 of the file because whenever I click browser download it is downloading part 1
Try firefox. Then move download window on screen, you will find onother below.
Admaiora
i found both parts but its says file corrupted aft running the application
delete all corrupted anterior parts.
Download again both parts
Admaiora
known issue downloading from Autodesk.
You'll have to try various methods to download from them, the browser download is known to be buggy and usually doesn't work. There usually is an alt method to d/l, it's just not always easy to locate it.
I'd suggest the link the Autodesk person suggested earlier but I can't locate what you are attempting to download from there.
I chose the download link from the link sent by autodesk person and went to inventor products and I tried to download inventor 2012,2013 and 2014.. none of it works.. its shows corrupt file error .. I dunno what else to do
There some problem on your machine/browser or in your procedure.
I have tried this now, and all works fine.
Admaiora
Ya I jus now found that I could not install any of the autodesk products.. I have to fix that
please try to disable EPM in your IE on Win8.1 refering to below link, http://support.microsoft.com/kb/2864914. then, have a try to donwload the files again
