Inventor Forum
Inventor 2014 Bolt issue
2 REPLIES 2
234 Views, 2 Replies
Hey Guys! I New User on Inventor 2014. I Have taken classes to learn how touse it but i have a question about because I have been my hair out over it. In my assembly I am Trying to add bolts on a wheel hub. But when I try to add it after it loads it tells me that I need to delete or suppress objects but im not sure what parts I have to fix. Any help would be greatly appreciated!!
2 REPLIES 2
mcgyvr
Notice how at the top/middle of the program in the bar up there it has Pass Side Rear Upper Control Arm Assembly (LevelOfDetail1)
That (LevelOfDetail1) lets you know that you have suppressed a part at some time and Inventor wants you to save that levelofdetail or unsuppress the components you have suppressed previously.
You should be able to simply expand the representation folder in the model browser and go back to master or similar.
I'm not exactly sure why its causing a problem with your bolted connection generation though.. (because I just I don't use that bolted stuff)
Maybe after you go back to the master LOD either it fixes it self or I might try a rebuild all.
in reply to: mcgyvr
Thanks Man! Got two of the errors to go away but theres still one that says i have two delete or suppress it. Thankyou for your Help thugh.
