I have a major problem. Inventor 2014 will instantly crash out and close if i attempt to use my Nvidia Quadro FX-880M graphics card. The program crashes the moment you try to open a part, or create a new part. I disabled the graphics card in the device manager, and the program runs fine. I then switched to "software graphics" and the program will run in this mode, even after i have re enabled the card in the device manager.
I have done some searching, and I see that several users are running the Fx-880m with inventor 2014. I am mystified as to what you have done to make this work. I would greatly appreciate if someone could chime in and help me out with getting the software and hardware to play along nicely.
Thank you.
I am running Windows 7 64 bit.
Lenovo W510
8gb of ram
Are you guessing at a solution?
I have downloaded the newest drivers, the previous drivers, as well as the original drivers that shipped with my system. None of them work. All drivers require the "software graphics" to be selected in Inventor 2014.
I have also deleted every autodesk product from my system, used the cleanup utility, and did a complete re-install of Inventor 2014 with the fancy new drivers and it also instantly closes.
I would like to hear from sombody who is using this card, and what their setup is.
I am not sure what other graphics cards might be on the motherboard. I have nothing else listed under "display adaptors".
See if you have this setting in your Nvidia control panel
