Hello everyone,
PLEASE HELP! - this problem drves me crazy. It seems to be trivial but I cannot resolve it.
I created a part ROD.ipt; a cylinder. In it's Parameters table, d0=3 ( stands for diameter) and d1=12 (length). Next, I made Excel spreadsheet (file name: DATA.xlsx) which looks like this:
A B
ROD_DIAMETER 3
ROD_LENGTH 12
Then, I embedded the DATA.xlsx using "Link" in Parameters table.
iLoic rule to assign parameters (named ASSIGN_PARAMETERS) was created:
d0=GoExcel.CellValue ( "3rdParty: Embedding 1", "Sheet1", "B2" )
d1=GoExcel.CellValue ( "3rdParty: Embedding 1", "Sheet1", "B3" )
After I ran the rule, the following message appears:
Error in rule: ASSIGN_PARAMETERS, in document: ROD.ipt
The given path's format is not supported
Please take a look at the attached .ipt and .xlsx files. I 'commented all lines in the ASSIGN_PARAMETERS rule and changed DATA.xlsx to DATA.xls for files to be transferred.
Please let me know what I am doing wrong.
Thank you.
Solved by pcrawley. Go to Solution.
You've put this in your rule:
d0=GoExcel.CellValue("3rdParty: Embedding 1", "Sheet1", "B1")
d1=GoExcel.CellValue("3rdParty: Embedding 1", "Sheet1", "B2")
But it should read:
d0=GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "B1")
d1=GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "B2")
The difference is the space after "3rd" and the space before "Embedding"
Subtle - but critical 🙂 That's all it was.
Don't forget you can put sensible parameter names in Inventor - you'll get lost pretty quickly if you keep using d0, d1, d2 etc.
Good Evening pcrawley,
Thank you so much - that all it was! - Such problem wouldn't be a problem from now on.
Could you please suggest any technique to make my part updating automatically as soon as I click the "save" button in Excel? - I would really appreciate your help.
Glad I could help! (Feel free to mark the response as a solution and give Kudos!!)
Since your spread sheet is embedded, the link should be "live" - ie Change the parameter in Excel and the model will update as you type. However, after embedding the spread sheet, a common mistake is to think that you should be editing the .XLSX file to change your parameters. You don't. Delete the .XLSX file - it is no longer needed.
If you have embedded the spreadsheet, you'll see it is available under the "3rd Party" folder at the top of your model browser. Expand it and double-click the "Embedded1" (or whatever it's now called) to edit the spreadsheet. You should find the updates are immediate. Be careful with this though - if your model starts getting big and you have a lot of parameters, your performance can bog down. If you are heading towards bigger models, I strongly advise you get into skeletal modelling and passing parameters between parts that way rather than embedded spread sheets.
If it doesn't update dynamically, check:
1. Check this setting in your parameters dialogue box:
2. Check this in your iLogic Rules Editor:
Peter
Thank you Peter,
I have everything you mentioned checked... the Parameters table updates immediately; regardless, the part is "waiting" for the rule to be ran again, before it changes shape visibly. To the rule, I added following:
InventorVb.DocumentUpdate(True)
and also listed the rule in all Event Triggers. Yet, after the spreadsheet values are changed and the Excel file is saved, once again - part is not changing unless the rule is ran; which doesn't happen automatically.
If you think it could be a way to fix it, please let me know.
Thank you again Peter.
Oops - my mistake. It works dynamically when you write data from Inventor to Excel, not the other way round sorry.
