Error Message: A software problem has caused Autodesk Inventor to close unexpectedly
Autodesk Inventor 2013 was installed on a Win XP 32 bit machine. When opening, this crashes and the following splash screen appears (see attachment).
Also I am adding the dump.zip generated when the user tries to open the application.
The user experiencing this issues have uninstalled the application and re-installed and loaded service pack 2 but the issue is still there, including update 1.
Can you please help me troubleshoot or read the dump file, so I can help this user please?
Thank you
Hi Eunice Chagoya,
Usually, this kind of error is due to:
In order to resolve such an issue, it is recommended that you isolate the issue from other variables. You can apply several methods as below:
First of all, please check below points:
Secondly, I would recommend you to uninstall/re-install your product completely. This will mostly fix any issues from corrupted installation. Please refer to the following TS:
How to remove all Autodesk products from a Windows system
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
