I have just installed IV2013, i have an issue with the visual style. I use it with shaded with edges, however after saving closing and then reopening it it comes in as shaded only.
Is there anyway to permentaly changing this so that when i open models it they are shaded with edges.
isn't it the same setting as 2012 (not installed 2013 here yet)
application options -> Display tab:
tick "use application settings" instead of "document settings" and click the "settings" button
here set "shaded with edges " as visual style (along with any other options).
Does that help?
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
