Inventor General Discussion
Member
0 Kudos
Post 1 of 7
Inventor 2013 - Views and Dimensions not visible
675 Views, 6 Replies
11-01-2012 09:21 AM
The details are there but I can't see them until I put the cursor over them.  Enclosed is a jpg of the problem.
Ram for Inventor process is at 700-800,000 k-bytes.  My graphics card is a Nvidia Quadro FX580.
Anyone have a clue?  Thanks in advance.
2,120 Kudos
Post 2 of 7
Re: Inventor 2013 - Views and Dimensions not visible
11-01-2012 09:23 AM in reply to: jjha
Have you installed Service Pack 1.1?
Can you attach the files here?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Product Support
32 Kudos
Post 3 of 7
11-05-2012 09:11 AM in reply to: jjha
I have seen certain type of geometry cause this, ellipses and splines that are used in sketches to create model edges. Ex. Like a water tank to where the lid is like a dome. This in the past has caused views not to display. I would suggest getting the files to Autodesk to look at.
Don
Member
0 Kudos
Post 4 of 7
11-06-2012 11:46 AM in reply to: jjha
@JDMATHER.
Sp1.1 was installed last week.  This problem is evident in multiple files.  Atttached is one of them.  Observations suggest that this problem is memory related (see jpg attachment)
If so, why would 700,000 kb be a trigger????? Just curious.
JJ
PS.  file is too large to attach
3 Kudos
Post 5 of 7
02-04-2013 09:29 AM in reply to: jjha
I have a customer with the same problem.
Any fixes yet?
Member
0 Kudos
Post 6 of 7
02-06-2013 09:31 AM in reply to: BassEngineer
no solution yet except to recreate the file a different way.  it could also be dependent on texture and surfases attached to the ipt/iam and Inventor losing track of where the texture/surface files are located.
Sorry I couldn't be any more help .  Inventor has had lots of bugs since I've started to use it (2008) and I've come to accept that it will always have lots of bugs with no fixes.  Just make do until the next release comes out.
771 Kudos
Post 7 of 7
02-06-2013 11:05 AM in reply to: jjha
I suspect it's your graphics card, the FX580 is a old and slow card. This card has a performance rating of 304 (average G3D Mark) I would be looking at a new card, you are probably still on old drivers as well. This card is ranked 570th in graphics card rankings.
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
