Greetings All,
Can anyone tell me how I can find ot what SP is installed for Inventor 2013? Also, what is the latest SP for Inv2013 and is it stable for me to install the latest SP's?
Does the latest SP include all the minor patches and updates that are ot there in separate files?
Thanks in advance! 🙂
DJD
P.S. It's been some time since using Inventor of any release, but learning Inventor 2013 is like starting from scratch. (I blame senility)
If a SP was installed on this version of Inventor..... would it show in the "about" window? Or is the SP represented by the Build number?
I remember from previous versions of Inventor (unless I'm just THAT senile) the "about" window would display the SP version, if it was installed. This window as you can see from the attachment doesn't show an SP # per se, just a build number.
Basically, I'm trying to understand if the IT guy installed the SP or not. He tells me he has, but I'm into a few buggy issues with Inventor 2013. Doubtless, operator error, but I'd like to at least know that Inventor is up to date from a functionality stand point.
Edited by
Discussion_Admin
Perfect...... thanks! 🙂
Hmmm, I remember your ID from when I posted here way back around 2008'ish or so.
You should not post personal serial number on a public forum.
The CADWhisperer YouTube Channel
