Inventor Forum
Inventor 2013 Service Pack 1.1
16 REPLIES 16
Message 1 of 17
jdits7
2790 Views, 16 Replies
Autodesk has released SP1.1 for Inventor 2013, read all about it here.
http://inventortopix.blogspot.com/2012/10/inventor-2013-sp11.html
jdits7
Autodesk Inventor Certified Professional
Blog - http://www.inventortopix.com
Twitter - @InventorTopixJD
16 REPLIES 16
Message 2 of 17
Jon.Dean
in reply to: jdits7
Message 3 of 17
tuiengr
in reply to: Jon.Dean
Should this update be installed before or after the Factory Suite 2013 update?
Inventor 2013 Professional SP1
Windows 7 Profession, 64-bit SP1
Intel Core i5 CPU, 8GB RAM
NVIDIA Quadro 600, 4800 MB
Message 4 of 17
in reply to: jdits7
Tried to install and got an error "No valid sequence could be found for the set of patches".
Tried this with SP1 uninstalled and also tried it with SP1 installed.
Any one have any ideas?
Windows 7 64bit
Inventor Pro 2013
Message 5 of 17
Message 6 of 17
avaya2012
in reply to: jdits7
Has anyone been having any issues after installing the Service Pack 1.1?  I installed it yesterday thinking it would help  my issues.  Inventor still loves to crash when I am checking parts and drawings into Vault.  It also seems to be crashing at more random times.  If anything the service pack seemed to cause more issues than it fixed.
Message 7 of 17
PolemEngineering
in reply to: jdits7
I was informed by the Communication Centre. Today I installed this patch. The first thing I noticed is that after installing and restarting my system the communication center still say there is an update available.
A bigge rproblem is that I'm not able to open files from Vault. Open from local workspace is possible, but when I choose "Browse to a file in the vault and open it" the browserscreen disappears.
I will unistall this patch because I can't work this way.
René
Message 8 of 17
david.harris
in reply to: jdits7
Please make sure to install the Autodesk Vault 2013 Hotfix: DL19384851.
Best regards,
David
David Harris
Inventor Quality Assurance Team
Autodesk, Inc.
Message 9 of 17
avaya2012
in reply to: david.harris
I cannot add just that hot fix.  I get an error that reads "Error applying transforms.  Verify that the specified transform parths are valid."  The way I understand it, this hotfix should have been installed with the service pack anyway.
Message 10 of 17
david.harris
in reply to: jdits7
This Hotfix applies to Autodesk Vault 2013.  It is not included in the Autodesk Inventor 2013 SP1.1.
Can you share some information about your configuration and install locations?
Best regards,
David
David Harris
Autodesk, Inc.
Message 11 of 17
avaya2012
I am using Autodesk Inventor 2013 along with Vault Professional 2013.  I have Autodesk Inventor Service Pack 1 and service pack 1.1 installed.  Inventor crashed 3 or 4 times since 7 this morning and each time I was given a link for this same hot fix.  Do I need to install any updates for Vault itself?
Message 12 of 17
JimSteinmeyer
in reply to: avaya2012
David,
I will add to Avaya's question When I look at the vault hot fixes I do not see anything specifying if the hotfixes are for the vault server or the individual client (user) machines So far we have been installing them on user machines, Is this correct? Are there SPs or hotfixes for the Vault as well?
Thank you
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
Message 13 of 17
Hi Jim,
I am consulting with the Vault team now to see if they have seen this issue before.  The Vault Hotfixes are seperate from the Inventor Hotfixes and Service Pack.  There is a Vault Service Pack coming soon.  I believe that the majority of the Vault Hotfix should be installed on individual user machines, as you have been doing.
BTW: I did test the install on my machine earlier today and did not experience any issue during installation.
Best regards,
David
David Harris
Autodesk, Inc.
Message 14 of 17
Iam having a problem installing Vault 2013 Service pack 1 (Client)
I've installed it on a few computers successfully but get this error when tryiong to install on my computer.
We are running Vault 2013 Basic on 64-bit machines.
My specs are the same as one of the computers which have been upgraded succesfully. The only difference is that my computer is the VM server with ADMS on it, but that wouldn't be the issue would it? Vault Server SErvice Pack has installed successfully.
Cheers,
Emille
Message 15 of 17
david.harris
Hello Emille,
I have enlisted someone from the Vault team to help resolve this issue. As soon as I have some feedback I will pass it on to you.
Best regards,
David
________________________________
Autodesk Limited
Registered Office: One Discovery Place, Columbus Drive, Farnborough, Hampshire GU14 0NZ
Registered in England and Wales, No. 1839239
Message 16 of 17
JohnHuber
Hi Emile,
Please run the following to produce an installation log file and post it for analysis.
Msiexec.exe /p [path]\"Autodesk Vault 2013 Service Pack 1 (Client).msp" /L*v c:\2013SP1.log
John Huber
Engineering Escalation Team
Autodesk, Inc.
Message 17 of 17
in reply to: JohnHuber
Hi John,
Someone from the Vault team got back to me. Turns out it was an error in a Vault registry entry.
Always scared of just going into regedit on my own assumptions, but it was confirmed by the Vault Specialist and worked.
Cheers,
