Since some time im using inventor 2013, when working in assemblys everything is going way to slow.
Are there some things in the settings or whatever i can change?
My notebook specs are:
Inter core I7- 3610QM @ 2.3 ghz
Nvidia geforce 610M 2gb
6gb memory
Win 7 premium 64bit.
Thanks in advance!
Hello all,
We experiencing here performances issue with inventor 2013.
Running assembly (above 3000Pcs) is now really painfull since we merge from IV2012 to IV2013....
Create new part/drawing trough new button is really slow (1 @ 2 seconds to change the focus when cliking on another template... )
Let us not speak about creating a section view in a drawing....
Is something wrong with our project configuration? what happends with that 2013 version..??
Hellllppppp
Our configuration is (the same that was for IV2012...) :
* Product suite Ultimate 2013 SP1.1 + vault basic 2013
--> using one project (vault project) for all our files
--> Librairies and template are on a shared files on the network
* Computers:
Windows Pro 7 64bits SP1
2x Intel Xeon E5520 @2.27GHz
6 Go DDR3 667MHz
NVIDIA Quadro FX1800 768MB
I'm having the same issues as well - Win7 64bit, i7 CPU, AMD HD7990 6GB GPU, and 32GB RAM - All files are locally stored. Help?
It seems like all of you are running on 6Gb RAM? Here are the requirements for IV 2013 on Windows, recommended for larger assemblies:
We run on 12Gb, with these specs:
AutoCAD 2013, IV 2013 Pro SP2 Tube and Pipe - Frame Generator, Vault Pro 2013 Win 7 x64, Dell precision PWS690, GeForce GTX580
Large assemblies still load somewhat slowly, but not to where we can't live with it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
FYI: http://usa.autodesk.com/autodesk-inventor/system-requirements/
Should have included that....
Chris Benner
It's not just them, and it's probably not an issue with the RAM.
My workstation at the office is a Xeon E3-1280 w/16 GB and I get a lot of slow-downs as well. My laptop at home - i7-2630QM w/6 GB - ran Inventor Pro 2013 better than my workstation. (Well, laptop has 8 GB now, but it worked just fine at 6.)
There's a few things that can be done to speed up the machine, but they're not necessarily magic bullets.
First thing, you can go to the Tools tab and open up the add-in manager. (Use the one from the tools tab, not the Add-Ins tab.) Turn the things you're not using off. For me, I turn off the Mold Design, Routed Systems, Eco Materials Advisor, Dynamic Simulation, and a few other things. It improves the load times a lot.
The things that mostly slow down for me are things like drawing updates, fillets and draft operations. Sometimes I just have to shut down and reboot.
Rusty
No, that's a 6GB GPU/video card.......... I'm running 32GB of RAM.
I shouldn't have these hangups like I'm having - Like with just ONE file/part/window open... Nothing else running in the background, besides Outlook, Windows Explorer, and Inventor 2013 64bit. It's a simple part, too!! Just 12 dims..... LOL wtf?
Bump for that! I'll try that out... Definitely! Thanks.
(Still searching for a FIRM answer/solution from Autodesk, though.. lol)
I try too put our design data and template on a local HDD instead of the local network change my project to point to the local data and... There is some improvement !!
Drawings are still painfully slow but now when cliking on the new button and choosed what to create (parts, assembly, drawings...), screen don't freeze anymore for long seconds.... But no matters we use a local design data and template are we need all to work on a common version...
For sure something change in Inventor 2013 with the network access !!! Please could an autodesk employee tell us what's change beetween IV 2012 and IV 2013 with the network connection??
PLEASE!
Because I just waited over a minute to change a content center bolt's length, for it to 'update part'.... Dang.
I can't be dealing with these hangups like this, guys... I have models to make, and products to push out!!
Weavty1,
Did you migrate your content center files, your styles, colors, templates, etc...
Did you used Vault?
Is your content center on the network, on vault or in local on your machine?
We need to find what's wrong...
I'm not Weavly, but I do have some of the same issues. I don't think it's quite as slow as that, but it's still pretty slow.
I have a Vault, but I don't use it - my project is set up to be completely local and self-sufficient. Everything is on the local machine. Everything is migrated, except for Content Center which was a new installation for 2013. (2011 used the network content center.)
Rusty
Content Center files are all stored locally. All Styles are as well, etc.
I had not migrated anything from a legacy version, nor have I used Vault for anything yet. So I should not have any issues with that at the moment.
Everything is installed and ran locally on my workstation (PC) here at the office.
Are you running an SSD or HDD? If you are running a 5400 RPM HDD you will definitly experience slowdowns.
Randy
Intel Xeon W3565 3.2 GHZ
12 GB Ram
256 GB OCZ Vertex 3 SSD
ATI FirePro V5700
I'm equipped with 7200RPM HDDs, but even if I was using 5400 Rpm HDD they shall be not have a so big difference between Inventor 2012 and Inventor 2013...
From what I see from this post, we all have a well configured computer (Up to 32Gb RAM in this thread) to run Inventor whithout been laggy....
And it happens that we use network or local files, Vault or not...
Attached a video of the new function slow down between network (H:) and local (D:) drive. See How it's slow with Inventor 2013...
My experrience is that if I change project I have to restart Inventor. If not the Inventor is very, very slow. Also missing file of material library (adsklib) slows Inventor. Could not be this your problem?
I experienced the same performance issues after I installed PRDSU2013 (one small assembly of 40+ parts took 2 hours to open). The problem (for me, at least) stemmed from the custom material definitions I had created in 2012 and previous, which did not migrate successfully to the new release's Material and Appearance Libraries definitions. I also have alot of custom content in the Content Center, which affected the performance as well. My solution required purging all of the custom definitions and applying a new, similar one from within the new libraries. Unmodified definitions had to be updated. After many, many hours of purge/update, 2013 now runs @90% of the speed of 2012. Not great, but much better. I'm still trying to track down some pesky problems in some sheet metal parts.
If you create any custom materials/appearances, I would recommend following the steps outlined here:
The process is a little different depending upon whether it is begun from within an idw or iam/ipt
When in a idw, follow these steps in order:
When in a iam or ipt, follow these steps in order:
This is an ongoing process, obviously, and I re-create my custom materials and appearances as needed, or when I have time, using the Asset Management project defined above. If any of my custom materials had been applied to custom items in the Content Center, then they have to be redefined, too.
This may or may not affect your issue, but perhaps it will help..
