Inventor General Discussion
JDMather
Message 11 of 30 (1,596 Views)
Re: Inventor 2013 "half section view" mode
01-09-2013 11:03 AM in reply to: vheller
vheller wrote:
Please note that all information in this file is confidential.
Then I strongly suggest you not post where everyone can get it.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
vheller
Message 12 of 30 (1,588 Views)
01-09-2013 11:39 AM in reply to: JDMather
Any other way to grant you access to this file to investigate an issue?
dan_inv09
Message 13 of 30 (1,582 Views)
01-09-2013 11:49 AM in reply to: vheller
So, let me get this straight, you are trying to create a section view on a drawing?
I would start by trying to make the section view a little bit to one side of where you are getting the problem. Then try far enough that some parts would be excluded if it's an assembly (in a part, I guess, you would want to get past some features, like if there's an extrusion or a loft or something). If you can get a section to work then you look at what is where it didn't work.
dan_inv09
Message 14 of 30 (1,582 Views)
Re: Inventor 2013 "half section view" modeI put an assembly in another assembly
01-09-2013 11:52 AM in reply to: vheller
Active Member
vheller
Message 15 of 30 (1,575 Views)
01-09-2013 12:18 PM in reply to: dan_inv09
There is only one drawing attached - GA-002.dwg, I guess... Yes, I'm trying to make section view in that one to show both sides of the skid from inside center line.
Active Member
vheller
Message 16 of 30 (1,547 Views)
01-10-2013 11:29 AM in reply to: dan_inv09
Doesn't really work... I can't create any section view from this assembly, even if I hide some stuff in view.
Active Contributor
tommy-z
Message 17 of 30 (1,521 Views)
01-15-2013 05:44 AM in reply to: BrianSchultz3877
As always when Autodesk makes "improvements" to the user-interface we get some new and (sometimes) interesting features, at the expence of some or other of the useful, or at least workable, features which we have gotten acustomed to.
It surely must be a mistake that when wanting to create a "Half Section View" in an assembly, we are not able to "sign out" this action by just using the enter button.
What is the rationale, what on earth is the improvement over previous versions of the wonderful tool called "Inventor", that after selecting: "View" -> "Half Section View", then clicking on a plane / part surface and consequently dragging the offset to "whatever", adjusting the offset by typing in a number in the dialog-field, and then hitting "Enter" to confirm: The whole dialog-box disappears, and then you cannot just hit "Enter" to confirm that you in fact do want to create such a "Half Section View"?
No, no - you then, off course, have to right-click (which miraculously makes the dialogue re-appear) for the final click on the "OK" button.
Quelle Magnificence, Quelle Luxe!
NOT!
Active Member
vheller
Message 18 of 30 (1,505 Views)
01-15-2013 08:41 AM in reply to: dan_inv09
Hello.
It does work. The wierd thing is instance of same subassembly caused this problem.
Thank you.
Member
alvinm
Message 19 of 30 (842 Views)
11-19-2013 09:20 AM in reply to: BrianSchultz3877
Hi, I'm having the same problem. Can someone tell me if there's a way we can still measure when the Half Section view still on??? I used to able to do it in 2012 and 2011.. why would they change that.. it was a big feature I used everyday..
Please email me if someone has a solution.
Certified Engineering Technologist
mrattray
Message 20 of 30 (835 Views)
11-19-2013 09:35 AM in reply to: alvinm
Did you make sure to right click and then click enter to accept the section view? If you don't, then trying to use the measure command will cancel the section.
Mike (not Matt) Rattray
