Does any body know why Inventor 2013 cannot open an *.prt (Pro/E) file as attached?
I can open it in Inventor 2009, but when I tried to open it in Inventor 2013, it said "Unable to convert Pro/ENGINEER or Creo Parametric file to Inventor file."
Solved by JDMather. Go to Solution.
Opens well as Pro/E-PRT in 2010, too.
2011 and newer versions refuse.
Comments from ADesk are welcome.
Walter
Walter Holzwarth
First thing I noticed is that there was a space in the filename. Pro/E doesn't allow spaces in filenames?
After removing the space - I was able to open the file in Creo 2.0
Edit - I was able to open the file in Inventor 2013.
The CADWhisperer YouTube Channel
Interesting; Jeffrey.
Renaming to RPEE_LEN.prt did it here, too.
Walter Holzwarth
Opens here too, after taking the space out of the file name.Inventor 2013
Dell Precision T3500
Windows 7 64-bit
12GB RAM
dual NVidia Quadro 2000
Driver 297.03
Thanks lot, Guys!
After removing space, it works.
Inventor 2009 accept space, 2013 does not.
