Meu inventor 2013 x64 português não abre, estou usando o windows 8 porem no windows 7 ocorre o mesmo problema. Ja mandei esse relatorio de erro e me pediu pra atualizar para o sp2, atualizei e continuou com o problema em ambos os sistemas operacionais. Até o momento a autodesk não me mandou nenhuma solução e queria ver se vocês podem me ajudar.
Olá Filipe.
Experimenta tambem actualizar o próprio inventor:
Faz o download do service packs mais recente para win64bits e volta a tentar.
Encontras o service pack para Inventor 2013 64 bits aqui:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019#section16
Cumprimentos.
As of August 14, Inventor 2013 is not officially supported on Window 8. Many people have managed to get it to run. Part of the problem seems to be with .NET 4.0 and .NET 4.5
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=12305695
Hi!
Maybe is a Graphic issue that shuts down the Inventor.
(Tip, open the program and let the mouse, don't move the mouse until the program load completely. If the program loads fine, see if the program shuts down when you start to move the mouse.)
Update also the graphics card's drivers.
Regards.
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below
