Inventor General Discussion
Product Support
36 Kudos
Post 11 of 22
Re: Inventor 2013 - missing dimensions in drawing
05-31-2012 06:21 PM in reply to: mrattray
Hi Matt,
I couldn't able to reproduce the problem. See below screenshot. Since you are using a custom template, can you share that with us for further testing.
Also please check with different options for graphics under Application options -> Hardware tab to see whether you can reproduce the same behavior.
Let me know your test results.
Vinod Balasubramanian
889 Kudos
Post 12 of 22
06-01-2012 04:58 AM in reply to: VinodBalasubramanian
I played around with the options in the hardware tab and still was reproducing the problem with every combination of options.
In the file set that I posted earlier in this thread the glitch only presents in the right view, the top view dimensioned OK.
Find the problem template and my application options export attached.
Mike (not Matt) Rattray
Product Support
36 Kudos
Post 13 of 22
06-03-2012 08:25 PM in reply to: mrattray
Hi Matt,
I tried with your template and the same application options settings. I couldn't able to reproduce the behavior on my end. It looks more of a graphic issue at the moment.
Have you tried switching your graphics options in the hardware tab under application options. Can you able to reproduce the same problem ?
889 Kudos
Post 14 of 22
06-04-2012 04:53 AM in reply to: VinodBalasubramanian
Product Support
36 Kudos
Post 15 of 22
06-04-2012 07:52 PM in reply to: VinodBalasubramanian
Can you confirm whether you have installed a certified graphic card driver for Inventor. If not you can download them from the link below,
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
889 Kudos
Post 16 of 22
06-05-2012 04:40 AM in reply to: VinodBalasubramanian
I don't have control over our hardware here and the IT dept. thinks that workstation grade hardware is unnecessary. I'm stuck with a gaming card, AMD Radeon HD 6670, with no available certified drivers.
Product Support
47 Kudos
Post 17 of 22
06-06-2012 11:20 AM in reply to: mrattray
Guys,
I think I have found an explanation for what you are seeing.
This is actually as designed and is the result of the text clipping around hatches and dimensions that we implemented in 2013. See the wiki help:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0000-What_s_N0/0001-What_s_N1/0058-Drawing58/006...
The easiest way to explain why this happens is to look at this screenshot.
Dimensions sitting within the area designated by the green dots, will be clipped.
To avoid the issue , use smaller textboxes  or create the larger (empty) textboxes inside a draft view.
Cheers
Bob
889 Kudos
Post 18 of 22
06-06-2012 11:26 AM in reply to: bobvdd
I think you got it, Bob! Thanks! I'd mark it as solution but, I'm not the OP.
Note to self: avoid unneccessarilay massive text boxes.
Thanks again, Bob!
New Member
0 Kudos
Post 19 of 22
04-30-2013 01:27 PM in reply to: bobvdd
Bob, your post made my day. I was in a rush to get some drawings out for quotes and kept having the disappearing leader/dimension problem. When I moved an adjacent text box, after reading your post, the issue resolved. So the cause is overlapping text boxes and is easy to fix.
Regards, Bill
Product Support
47 Kudos
Post 20 of 22
04-30-2013 01:36 PM in reply to: billmace6
Thanks Bill for confirming the solution!
Always good to get positive reaction to a post that was made almost a year ago.
Just an extra proof of the benefit of this newsgroup.
Bob
