Hi, I'm relatively new to inventor, but have been using solidworks/Pro-E for the last few years. As a training excercise and for design intent, I decided to use linked parameters for a recent assembly. I needed parts to reference the assembly and assemblies to reference parts. After receiving an obvious cyclical reference error, I decided to create a "sketch-only part" consisting of all dimensions I needed to pass on. Due to company policy, I had to change the name of my parts to their standards for submission. I noticed, that when I did this, despite updating all part and assembly references, the "linked parameters" were still referencing the old file path.
I could relink all of them, but after you enter the new file path, the "user parameters" cause the new linked parameters to add "_1_2_2..." and so-on, thus making you remane all of the dimensions in the part with the new extension. This is fine for a few, but I have more than a few.
I'm not experienced in iLogic, but I believe this may offer me a solution,
Any suggestions?
Hello i came across the same issue.
The Dirty way to do this is to
Side note… not sure what happens if parameters are not there.
what they need is the same button in the drafting manage tab
Hope this helps.
