Inventor Forum
Inventor 2013 - Lag Problem
14 REPLIES 14
Message 1 of 15
2170 Views, 14 Replies
Hi guys,
I have just installed Inventor 2013. I was running Inventor 2012 before and everything was fine.
Now, I am noticing that when I click to edit a dimension for a new part that I have created, it takes a few seconds of delay before I type anything. This is so annoying especially when you do it all the time.
I highly doubt it has anything with the spec of my desktop but anyway it is the following:
Model : HP Z400 Workstation
Processor: Intel(R) Xeon(R) CPU W3670 @ 3.2GHz
RAM: 16GB
Operating System: Windows 7 Professional Service Pack 1 (64bit)
Graphics Card: Nvidia Quadro 4000
Any help would be appreciated.
(N.B: I use a Logitech M500 corded mouse if ever it makes any difference.)
14 REPLIES 14
Message 2 of 15
jrapert
Not just in dimension editing.
Try switching off components visibility in assembly view in idw, or any general update, constraint application etc. the time-waiting donut just does not want to stop spinning. Very fustrating.
I wish I've never installed 2013. I could do nicely without the (for me) completely useless fancy complicated new material and appearance system.
Julian
IV2013 Product design Suite Premium.
Dell M6400
12 GB RAM
Windows 7 Ultimate 64 Bit
Nvidia Quadro FX3700M 1 GB
Message 3 of 15
in reply to: jrapert
Similar specs here -
IBM Thinkstation E30
Xeon E31240 3.3Ghz
8 GB Ram
Quaddro 2000
Latest service pack (1.1), Running Kaspersky antivirus
Same issue.
Anyone have ANY input?
Message 4 of 15
You might try adding an exception to your anti-virus so it excludes scans on the Autodesk folder and subfolders, to see if that makes any difference.
Message 5 of 15
karthur1
Under Tools>Application options.... make sure it is set to either Performance or compatibility.  Software graphics is the slowest.
Are you using custom materials/appearnces?  If you have not modified any you should be good to go with the default stuff that installs.
Message 6 of 15
It is set to performance - I've tried everything with no solution.
I have put in a request for exceptions in the Anti-virus, so far no response.
I have noticed that every click in Inventor causes Kaspersky to scan several files.
Message 7 of 15
DarrenP
try disabling kaspersky and see what happens
DarrenP
Message 8 of 15
in reply to: DarrenP
I would love to.  We're locked down tighter than fort knox, so I'm not allowed to disable kaspersky in any way, and I can't get any response from IT.
Message 9 of 15
Typical!
Message 10 of 15
L.van.Gorsel
Have you installed the Inv. SP 1.1 + update?
Do you use Vault?
Green check.png  Please mark "Accept as Solution" if it answers your question or "Kudos" if you found it useful
Autodesk Inventor 2013, 2014 & 2015 Certified Professional
Message 11 of 15
in reply to: L.van.Gorsel
Do you use Vault?
Yes, Service pack and update were installed this week, that's when slowdowns started.
We do use vault, that part of it is pretty good.  I little lag when opening new files due to being stored on the network, but otherwise vault performance is good.
*edited for spelling
Message 12 of 15
I would just like to confirm that I am seeing the exact same problem since installing Inventor 2013.
I am currently up to date with service packs and I also use the Vault.
The measurement tool lag sometimes takes over a minute to come back from unresponsiveness. I've also noticed my system RAM seems to take off and never come back down.
-Matt
Message 13 of 15
skyngu
hi
how do you find out "every click in Inventor causes Kaspersky to scan several files."? since i want to show it to IT department. thanks.
Autodesk Inventor Professional 2019
Message 14 of 15
in reply to: skyngu
On the Kaspersky status screen there is a list at the bottom that shows how
many files are scanned.
This list is updated in real-time. It turns out to be a Kaspersky
configuration issue. Inventor folders need to be entered as exceptions.
Also - the major cause of lag turned out to be outdated styles in the
template documents. A "purge" of old styles fixed the issue.
Telson Hadden
Engineering Technician
Beclawat Manufacturing Inc
966-5611 ext 230
Message 15 of 15
skyngu
thanks.
the outdated styles on template  were cleaned.
I can not even go to kaspersky status screen. IT department did a good job...haha
I see kaspersky is running in task manager.
