Inventor Forum
Inventor 2013 is running so slow that it's mostly useless
9 REPLIES 9
Message 1 of 10
drewstall
1220 Views, 9 Replies
Inventor 2013 is running so slow that it's basically worthless. I have tried all the advice in the forums and nothing has worked so far.
The only thing different about the requirements is the NVIDIA Quadro FX 3500 graphics card instead of the Direct3D 10. The other people in my office have the same set up and theirs works fine.
9 REPLIES 9
Message 2 of 10
Logos_Atum
in reply to: drewstall
Hello drewstall,
could you please post a system profile and the installed Nvidia Driver Version?
Sounds like a driver issue to me for I have been working on a quadro fx 3800
and it mostly worked fine. Apart from that I´m hopefully right when I assume you
are running same sized files as your colleagues do?
Kind regards
Daniel
Dogs aren´t flammable.
Message 3 of 10
pcrawley
in reply to: Logos_Atum
You say yours is the same configuration as the others in the office... but theirs work and yours does not.  So clearly there is a difference.
Try posting some useful diagnostic data that we can work with:  Run Inventor, start a part file, Tools > Application Options > Hardware > Diagnose... Press OK (to copy the results to the clipboard) then come back here and past it into a response.  There may be a clue here for someone.
Peter
Message 4 of 10
blair
in reply to: pcrawley
The quickest item to check would be in the Application Options>Hardware and see if the setting is either Performance or Quality setting within Inventor.
I have seen installs for some reason get set to Compatibility which will slow down Inventor.
Delta Tau Chi ΔΤΧ
Message 5 of 10
drewstall
Sorry I fell off the face of the earth for 2 days. Here is the diagnostic report:
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
AIRViz Device Manager \ VirtualDeviceDx9
Feature Level 3_1
Performance Mode
Hardware Renderer
Graphics driver file nvd3dumx.dll,nvd3dum is version 8.17.12.5896
Current optimization settings are not known
The display is using 32-bit color
Inventor Version:
Build: 200, Release: 2013 SP2 - Date: Fri 04/19/2013
64-Bit Edition - 8192.00 GB
System Information:
Operating System: 64-bit Microsoft Windows 7 Professional (Build 7601) Service Pack 1
Language: English
System Manufacturer: Dell Inc.
System Model: Precision WorkStation 390
BIOS: Phoenix ROM BIOS PLUS Version 1.10 2.3.0
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (1 processor, 1 core, Hyperthreading enabled)
System Memory: 7.935 GB RAM
Graphics Device Information:
Renderer: HAL
Manufacturer: NVIDIA
Chip Type: Quadro FX 3500
DAC Type: Integrated RAMDAC
Graphics HW Memory: 239 MB
Display Mode: 1920 x 1200 (32 bit) (59 Hz)
Graphics driver file: nvd3dumx.dll,nvd3dum
Driver file version: 8.17.12.5896
Driver Date: 9 July 2010 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description: NVIDIA Quadro FX 3500
Vendor ID string: 0x000010de
Device ID string: 0x0000029d
VendorID: 10de
DeviceID: 29d
SubSystemID: 32b10de
Revision: a1
Direct3D 10 / DXGI System Information:
Dedicated Video Memory: 239 MB
Dedicated System Memory: 0 MB
Shared System Memory: 1.984 GB
DxDiag System Information:
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language: English (Regional Setting: English)
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs), ~3.0GHz
System Memory: 8192MB RAM
Page File: 3010MB used, 13239MB available
DirectX Version: DirectX 11
DxDiag Version: 6.01.7601.17514
DxDiag Graphics Device Information:
DirectX Version: 10.0
DDI Version: 9Ex
DDI Version Number: 9
DxDiag WHQL Level: 0
Driver Signed Valid: True
Driver Signed: True
Revision:
Graphics HW Memory: 2270 MB
Display Mode: 1920 x 1200 (32 bit) (59Hz)
Driver file version: 8.17.0012.5896
Driver Date: 7/10/2010 05:38:00
WHQL Level: 1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
May/06/2013-08:02:01: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Failed to create a device from the adapter.
May/06/2013-08:02:01: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D11.
May/06/2013-08:02:01: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/06/2013-08:02:14: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Missing the appropriate installed version of D3DX.
May/06/2013-08:02:24: Fail to create D3D9 factory, We need to change it for current inventor session: D3D9 -> D3D10.
Failed to Create D3D object. Direct3d 9 factory initialization failed.
May/06/2013-08:02:28: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/07/2013-12:53:43: Reset to D3D11 factory: OpenGL -> D3D11.
May/07/2013-12:53:47: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/07/2013-12:54:21: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/08/2013-10:32:30: Reset to D3D11 factory: OpenGL -> D3D11.
May/08/2013-10:32:33: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/08/2013-10:32:41: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/09/2013-10:35:23: Reset to D3D11 factory: OpenGL -> D3D11.
May/09/2013-10:35:25: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/09/2013-10:35:28: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/09/2013-12:27:10: Reset to D3D11 factory: OpenGL -> D3D11.
May/09/2013-12:27:10: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/09/2013-12:28:10: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/09/2013-12:32:46: Reset to D3D11 factory: OpenGL -> D3D11.
May/09/2013-12:32:47: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/09/2013-12:34:21: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/09/2013-12:46:55: Reset to D3D11 factory: OpenGL -> D3D11.
May/09/2013-12:46:56: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/09/2013-12:46:59: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/09/2013-12:53:09: Reset to D3D11 factory: OpenGL -> D3D11.
May/09/2013-12:53:10: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/09/2013-12:53:12: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/09/2013-13:31:30: Reset to D3D11 factory: OpenGL -> D3D11.
May/09/2013-13:31:30: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/09/2013-13:31:33: Fail to create D3D9 factory, We need to change it for current inventor session: D3D10 -> OpenGL.
May/09/2013-14:32:00: Reset to D3D11 factory: OpenGL -> D3D11.
May/09/2013-14:32:00: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/10/2013-08:05:00: Reset to D3D11 factory: OpenGL -> D3D11.
May/10/2013-08:05:02: Fail to create OGS D3D9 factory, We need to change it for current inventor session: D3D11 -> D3D10.
May/10/2013-10:51:44: User changes the graphics driver manually: D3D10 -> D3D11.
Jul/03/2013-13:52:48: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/03/2013-13:54:10: User changes the graphics driver manually: D3D9 -> D3D11.
Jul/03/2013-13:54:16: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/03/2013-13:54:16: User changes the graphics driver manually: D3D9 -> D3D11.
Jul/03/2013-14:50:36: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/08/2013-07:35:57: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/09/2013-07:27:22: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/10/2013-12:57:40: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/11/2013-13:40:15: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/15/2013-09:27:46: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/17/2013-08:55:46: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/18/2013-07:28:19: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/19/2013-10:54:31: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/19/2013-11:20:06: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/19/2013-12:03:31: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/22/2013-07:45:22: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/22/2013-12:11:12: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/22/2013-12:17:47: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/22/2013-12:22:33: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/22/2013-12:33:07: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/22/2013-12:39:58: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/22/2013-12:46:43: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/23/2013-07:55:03: Reset to D3D11 factory: D3D9 -> D3D11.
Jul/23/2013-07:55:05: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/23/2013-12:56:22: Reset to D3D11 factory: D3D9 -> D3D11.
Jul/23/2013-12:56:23: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/23/2013-13:07:49: User changes the graphics driver manually: D3D9 -> D3D11.
Jul/23/2013-13:08:54: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/23/2013-13:08:59: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Failed to Initialize d3d10 environment. Direct3d 10 factory initialization failed.
Jul/24/2013-07:29:26: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-07:29:30: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Jul/24/2013-08:44:22: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-08:44:26: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Jul/24/2013-09:08:49: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-09:08:53: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Jul/24/2013-09:08:56: User changes the graphics driver manually: D3D9 -> D3D11.
Jul/24/2013-09:09:34: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-09:09:34: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Jul/24/2013-09:09:34: User changes the graphics driver manually: D3D9 -> D3D11.
Jul/24/2013-09:09:41: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-09:09:41: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Jul/24/2013-09:35:56: User changes the graphics driver by reading XML file: D3D9 -> OpenGL.
Jul/24/2013-09:37:35: Reset to D3D11 factory: OpenGL -> D3D11.
Jul/24/2013-09:37:35: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-09:59:40: User changes the graphics driver manually: D3D10 -> D3D11.
Jul/24/2013-10:05:01: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-10:05:05: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Jul/24/2013-10:19:18: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-10:19:21: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Jul/24/2013-11:22:51: Reset to D3D11 factory: OpenGL -> D3D11.
Jul/24/2013-11:22:51: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-12:15:49: User changes the graphics driver manually: D3D10 -> D3D11.
Jul/24/2013-12:39:08: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Jul/24/2013-12:39:11: Fail to create D3D10 factory, We need to change it for current inventor session: D3D10 -> D3D9.
Jul/26/2013-07:34:25: User changes the graphics driver manually: D3D9 -> D3D11.
Jul/26/2013-07:36:02: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Message 6 of 10
blair
Even though the 390's came out in 2006, I would think this machine should still run not to badly. Part of the problem is with the graphics card only being DxD10. Win7 really likes Dxd11.
I would check for any "conflicts" in the Device Manager and try reducing the number of programs running in the background.
Possibly a bad install. You had the UAC slider set to it lowest position and were logged in with Admin privileges. Depending on software, if you had a Anti-Virus software, it may need to be disabled for the install of IV.
Delta Tau Chi ΔΤΧ
Message 7 of 10
JDMather
I don't have any short fix for your particular problem.
But I recently restored an old slow 32-bit Vista (64-bit processor, so this box came out about the time of change-over from 32-bit to 63-bit) machine back to it's original OOTB set-up with only Windows Updates added and it now runs like new.  It was a two day job to get back to OOTB and update Windows and reinstall Inventor.
The CADWhisperer YouTube Channel
Message 8 of 10
pcrawley
So the nvidia FX3500 only has 256MB onboard RAM - that's minimum spec' for Inventor 2013 and 2014.
According to the graphics log file you posted, there have been problems since May initialising DirectX 11.  It then reverts to DirectX10 - which also fails, so it reverts to DirectX 9.  It's been doing that alomst daily since May - although I think you gave up working during June... The problem starts again on July 3.
Your drivers are somewhat out of date - you are running 258.95 - and the current version is 307.45  (I'm not advocating using the 'lates' drivers - this is just a suggestion to fix whatever is broken with the current version.)
You can check which version of DirectX is acrtually installed on your computer by going to the Start menu and typing in dxdiag into the little window at the bottom of the menu.  Run the diagnostic tool and it should tell you at the bottom of the first page the version of DirectX that is currently running.  There arre some tests you can run - something there might give you a clue as to the cause of the problem.
According to the nvidia drivers website, your card does support DirectX 11 with the latest driver installed.
Try the diagnostic tool - if nothing else it might give you the satisfaction of finding out what's wrong.  Then fix it.
Latest Nvidia drivers are here: http://www.nvidia.com/object/quadro-tesla-win8-win7-winvista-64bit-307.45-whql-driver.html
How to use dxdiag: http://windows.microsoft.com/en-NZ/windows7/products/features/directx-11
My final tip:  Go buy a decent graphics card.  Seriously - if you're using that thing all day and it's been running like a three-leg dog since May, the cost to whoever pays your wage is far higher than a new graphics card.  And please, DON'T buy mimimum spec' again 😉
Peter
Message 9 of 10
pcrawley
Sheesh... All that effort, and drewstall doesn't reply, leaveing us wondering if it was worth it.
Peter
Message 10 of 10
drewstall
Sorry I'm taking so long. I had important stuff to do last week at 1/100 of the normal speed. Nothing I did Friday helped. Yesterday I updated the drivers again, and that seemed to help even though the diagnostic in the Application Options indicates the same problem.
Jul/29/2013-07:41:16:   Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/29/2013-08:14:29:   Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
Jul/30/2013-07:28:35:   Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D9.
I this may be the best I can get as far as speed. Also, I think I may be getting a new computer as a result of the production drop. Thanks for all of your help.
