I can't get Inventor 2013 show a custom iproperty correct.
My iLogic rule is this: iProperties.Value("Custom", "myvol")=volume = iProperties.Volume
But the custom iProperty is a Yes or No.
Had no problem with this in Inventor 2011.
Kind regards
Henrik Graversen
Solved by Inv_kaos. Go to Solution.
I can't speak for the previous behaviour but I think the method below is better and it should give you the correct result.
volume = iProperties.Volume iProperties.Value("Custom", "myvol")=volume
I would say the double equals sign is causing it to give a boolean output.
Thank you 🙂
i added a bit more:
volume = iProperties.Volume iProperties.Value("Custom", "myvol")=Round(volume, 2) &" cm/3"
