Inventor Forum
Inventor 2013, iLogic, Volume or Mass
2 REPLIES 2
HenrikGraversen
2498 Views, 2 Replies
I can't get Inventor 2013 show a custom iproperty correct.
My iLogic rule is this: iProperties.Value("Custom", "myvol")=volume = iProperties.Volume
But the custom iProperty is a Yes or No.
Had no problem with this in Inventor 2011.
Kind regards
Henrik Graversen
2 REPLIES 2
Inv_kaos
in reply to: HenrikGraversen
I can't speak for the previous behaviour but I think the method below is better and it should give you the correct result.
 I would say the double equals sign is causing it to give a boolean output.
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
HenrikGraversen
in reply to: Inv_kaos
Thank you 🙂
i added a bit more:
iProperties.Value("Custom", "myvol")=Round(volume, 2) &" cm/3"
