We have issues with some existing assemblies that we need to do revisions on.
When we check it out of vault and update something like edit an extrusion by placing an extra participant or even creating an extra new extrusion it switches off the visibility of the reference parts in the idw which in turn makes the views jump all over the page and unattaches the dimensions and annotations.
Has any body else come across the same issue and do anyone have any solution to this problem?
Any help or advise would be appreciated.
Kevin
Kevin,
Can you post some images of this?
Specifically the browser showing the visibility off.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Kevin
As Scott mentioned, a screen shot would be helpful, ...what reference parts, and how is the visibility on them set before you make the changes? Do you use View Reps or LOD in the model, or are you setting visibility in the idw?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
