Hello everyone,
We are experiencing frequent crashes since we installed Inventor 2013 (3-4 times a day). We use HP Z400 and Dell M6600 with latest drivers.
Anyone have the same issue ?
Thank you,
Vincent
All,
The "Update1" was due to be posted today, but a couple of last minute issues were discovered that will mean a delay of a few more days; sorry about that but we need to ensure that we do indeed fix the intended issues.
Update1 will be a rollup of several hotfixes, some of which prevent crashes, (such as the mentioned spaceball issue), & others to address some key workflows that were not working correctly. A readme file will document the specific issues addressed.
Scott, all of the crashes you have sent us are indeed related to the spaceball issue.
Mrattray, Pedrosouza7530 - if you can confirm your some of your identity used when sending in your crash resports, I will take a look at what issues you are seeing.
As a final note, I would encourage everyone reading this thread to always send in every single crash report you are presented with, (including a valid email address will help us if we need to follow up with you). Even if you don't have time to add any comments about what you were doing, (which obviously helps us), please, just send them in regardless. We do look at them & use them to decide on the priority of what needs to be fixed.
Chris
What about crashes that do not create the CER? I've had instances with just the Windows crash report. Do you get feedback from MS about those?
I'll try to start putting a name to them. Usually I'm too PO'd to type out my e-mail.
I typically skip putting my email address in to aviod the canned "send us all your intellectual property" emails.
The Inventor 2013 "Update1" was just posted:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19656800&linkID=9242019
I hope this helps,
Chris
Chris
no other software to date has caused me so much greif, i just lost 4 hours of work today when it crashed, these issues are not minor they are major as it happens to me 3 times a day atleast, they should have been ironed out during a testing phase. I hope this patch is going to solve the crashing otherwise im seriously going to consider never buying inventor again
Sorry to hear that you're having troubles. If you let me know the email address you use when submitting crash reports, I can take a look to see the status of those issues.
Update1 addressed a lot of crash issues; note that we are also currently beta testing a pre-release version of SP1 which includes Update1 & has multiple other fixes included too. If you would like to try that then let me know.
Chris
chrisDOTmitchellATautodeskDOTcom
"...we are also currently beta testing a pre-release version of SP1..."
<snark>
It's called Inventor 2013
</snark>
We are giving up and going back to 2012 for our new jobs many are stuck in 2013 as we cannot back save. If that does not work I receive a lot of e-mails from solidworks reps.
I had the opportunity to beta test SP1, and I found that even the beta version fixed the very vast majority of my issues.
SP1 should be released by the end of day, Friday, (US West Coast time). Updates 1 & 2 have already been released & will be incorporated in to SP1. You can get that from:
If you want to try the SP1 beta build before then just send me an email at chrisDOTmitchellATautodeskDOTcom & I can provide access.
I would also be interested in the issues that are tempting you to revert to 2012.
Chris
It was supposed to be released on the 15th. If memory serves, it was released and then immediately taken down for some reason. Anyways, it should be out any day now. Considering that, I doubt they're looking for any new testers now. If you're interested in beta testing future items you could try e-mailing Dan Szymanski at danDOTszymanskiATautodeskDOTcom.
We have the same thing. Inventor 2013 and 2013 SP1 keeps on crashing, sometimes 8 times a day or more, on several machines. When it crashes is not predictable. All PC's are HP, workstations XW4300, Z400 and Elitebook 8740. PC's have latest updates running.
We use the standard Vault, and we want to go back to 2012, but this is no option because of the Vault update to 2013. Needless to say what to think about that. My co-workers (8 in total using Inventor) keep complaning, and I have no solution!
Looking forward from AutoDesk what the solution will be. What to do with lost time in production?
André
André,
Unfortunately most of the issues you are now experiencing are related to the problem that caused SP1 to be removed for further download this week. We hope to have an updated SP1.1 released within the next week.
In the meantime you can either stick with SP1 or uninstall it to go back to your previous configuration.
See this thread for info about uninstall:
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-SP1/td-p/3629426
Chris
