Inventor General Discussion
DWEN
Message 31 of 33 (176 Views)
Re: Inventor 2013 Failed to mesh
10-26-2012 02:02 AM in reply to: henderh
Last mont I had some problems with meshing. It turned out to be the panda virusscanner. Yesterday I did the service pack of inventor 2013. And agen no meshing. (even without panda virus scanner)
I am realy sick of these problems!
Employee
henderh
Message 32 of 33 (154 Views)
10-29-2012 10:03 AM in reply to: rschwartz
We have a similar issue reported through our product support channel, and Development has determined the cause.
I'm not sure if this is the same reason, that the meshing is not working on your machine, but it may be worth a try:
  • Create the following System Environment variables (Windows Start menu => type in search 'Environment'
GHS3D_SOC008=NF0008
GHS3D_TERA=TERAC
GHS3D_LANG=english
It could be that UAC control on your system is preventing these environment variables to be set temporarily by Inventor.
I hope this helps, -Hugh
Hugh Henderson
Simulation QA Engineer
DLS
Active Member
rschwartz
Message 33 of 33 (128 Views)
11-04-2012 02:57 PM in reply to: henderh
Hugh,
I created the system variables that you listed.  Inventor is still failing to mesh.  Please let me know if you can think of anything else to try.
Rob
