Hi
Please can someone help, Hopefully it's a setting or something I have done incorrectly.
When working in detail drawings inventor progessivly gets slower, the more information on the drawing, the worse it gets.
I was watching the task manager, For ANY command, the 1st core runs at 100% for up to 30 seconds, while this is happening, Inventor is dead.
EG, add a revision row, delete a symbol, zoom in or out, pan, add a dimension, move a leader etc.
for each command/move takes 10 to 30 seconds to get control, it took me 45 minutes, to add a revision row and print 15 drawings this morning.
Please help, it realy is slowing me down.
Solved by ChrisMitchell01. Go to Solution.
http://dictionary.reference.com/browse/Aluminum?s=ts
GDay Ray,
I always wondered about the origin of the word, now I know ...
But tell me, how does a Koala up a tree find these things?
I had to turn off backround updates of the views. there is a box to uncheck in your application options under the drawing tab.
Hi
I will try the Background update setting once again, my first experience was not successful, if anything just a general slow down across the board, so I switched it back on again.
I get the impression that I am only one of a handful of users with this problem, so drastic steps might be the order of the day.
I have considered rebuilding my computer, (Full format etc)
Then obviously re-installing Inventor, but logged in as admin and no antivirus etc.
Just a thought.
I had a hard drive go out so installed 2013 fresh on new HD, but experiencing all the same problems. The problems seem to be getting worse. Now I am having the views disappear, along with exporting an idw taking 40-60 minutes. Not sure what is different with 2013 but would like to switch back to 2012. Only problem is everything has been migrated to 2013. Hope to have an answer from Autodesk soon.
Reg,
Have you sent an example of this "slow drawing" to anyone at Autodesk ? Any additional info that might help us identify what's going on ?
Send me an email at chrisDOTmitchell@autodeskDOTcom & I'll arrange to get the data.
I know what a pain in the arse debugging issues like this can be... (yes, that is an "arse" not an "****", as I speak English, even though I live/work in the US. Rule Brittania 🙂
Cheers,
Chris
Hi, I am experiencing the same slow idw for large assemblies. Turning shaded plot off helps alot. But I need my idws with shaded plots... I¨m seeing the same processer load, the first thread goes 100% and Inventor hangs for about 30sec, this happens with every thing I do in the idw. (moving the view, zoom, pan etc)
In my case I do believe this is related to shaded plots. I¨m seeing the same with my workstation as well as my laptop. Same model/idw was NOT a problem with the previous release.
I¨ve been with Inventor since release 4 I believe, and with one of the early releases, 4-7 ?, there was a similar problem. But I do not remember what...
Hopefully Autodesk can look into this.
Jørgen
Jørgen,
Try going to Document Settings, Drawing Tab & change to "Always" for Use Bitmap, & select a suitable resolution - see attached image. This should allow you to still have shaded views but with improved performance. The shaded image quality won't be quite as good as it was previously, but it should be a worthwhile trade-off for better performance.
Chris
Hi, thanks for the advice, that actually helps. I am now able to move the views around and work with them.
I still feel in general that my drawings are a lot slower in this release than in previous. Telling a view (unshaded as well) to become associative freezes Inventor dead. But that might be another thread.
I really think this release has serious problems with idws. Im currently seeing the same problems with my two computers, and I did not have this problems with 2012. My templates and project files as well as idws, ipt, iams are migrated. (also libraries)
Jørgen
Jørgen,
Are you able to share an example of this drawing with us for further investigation ?
You can email me at chrisDOTmitchellATautodeskDOTcom & then I can provide you with a mechanism to get the data to us, assuming it's too large for email.
Chris
Hi all.
Chris has spent some time trying to debug my problem and came with some suggestions, as he could not reproduce my problem.
Needless to say, I still have the problem, I have just learnt to work around it, by restarting Inventor often, sometimes after working with one drawing at a time.
These did make a noticeable difference, I can work for a little longer than usual
- Set the system swap file to a fixed size, in my case 18gig
- Set the Inventor Undo to 2 gig, I set mine to 4gig
- Re-install/repair c++ and dotnet, this I have not done, as I am scared of destroying windows.
Hopefully Autodesk will find the problem, and release a patch soon.
Run the application from the link below:
http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
I've used it many times to try and troubleshoot mysterious slowdowns and lockups. It allows you see what your computer is doing while Inventor just shows 100% processor activity and ever increasing ram usage, but nothing else.
By applying a filter for the inventor.exe processes, or various other processes, you're better able to track down what the issue is.
For example, I once had a mysterious slowdown of AutoCAD and Inventor, and with the help of process monitor was able to determine that it was the windows feature Offline Files that was causing it. I disabled offline files, restarted, and all was well again.
You can wait for a service pack, but unless you've determined what the issue is (which is likely on your side if someone else can't reproduce it), it will never get fixed.
Reg,
Chris forwarded this issue to me along with the files you shared with him. I am able to reproduce the behavior you are seeing. So far I have not been able to pinpoint exactly where the problem is.
I do notice the assembly the drawing is referencing needs an update. After updating the assembly and saving all the files shown in the save dialog, I see the perofrmance seems to be better. Could you confirm that?
Thanks!
Hi, I¨ve received e-mail from Chris regarding this. When using Bitmap allways, the performance is better. I allways makes sure the files are up to date, but the packngo you received might not have been.
As mentioned in e-mail, I will use the bitmap mode, making sure all is up to date and hopefully we will see a service patch for this in the future.
Thanks for your efforts.
Jørgen
Hi Johnson
Regarding your post, Thanks, it's hard to say, as I am continually updating and refreshing as the build continues.
I have made a change which has all but eliminated the slow down.
I changed the Graphics setting to "Compatibility"
Guess what it works, The overall performance has dropped off, but its a small price to pay for stability.
At this stage I have not experienced the dreaded performance drop off, only time will tell. Making this setting has it's own set of display issues, Views disappearing temporarily, leaders and balloons look really strange while placing them, but after placement, they look fine.
The overall modeling side has had a slight performance knock as well, but not much.
I tried the Performance monitor the other day, works well, but to diagnose the information and to see what is acceptable errors becomes quite tricky, I did notice a few file not found and path errors regarding dotNET and the registry?
Quick Update....
Did about 30 drawings this morning.
Still working yay!
Hi Reg,
Thanks for confirming your findings; by coincidence we also noted that for certain drawings, (yours included), we are seeing better performance in the Compatibility mode, (Tools, App Options, Hardware tab for anyone else reading this).
We are investigating why this is the case, (since using that option essentially reverts the graphics engine to what it was a couple of releases ago), & will post an update once any definite conclusions are drawn.
Many Thanks,
Chris
I have the same issues as discribed, but also have problems in presentation files(ipn).
I'll be watching this hoping for a solution!
PC:
Intel Xeon 2.4GHz
6GB ram
Win7 64
Nvidia quadro FX1800
ToreM82
When you say you have the same problems, can you please confirm :
Or
What problems do you have with IPN's ? Performance or otherwise ? Are you able to share any examples ?
Chris
