Inventor General Discussion
blair
Message 11 of 23 (4,234 Views)
Re: Inventor 2013 export to dxf?
07-27-2012 09:49 AM in reply to: lpbug
You don't have the option in the DXF Out to select only the profile for exporting. Yes you can export your drawing to DXF but you don't have the option to select what you want to export.
We do a lot of CNC profile burning and on some shapes we need to Save-As to DWG and then go in and select what we want to export. I guess one could have a IDW template without any border of title block so all we would get is the model.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.60
SpacePilot Pro 3.06.109
Delta Tau Chi ΔΤΧ
mrattray
Message 12 of 23 (4,229 Views)
07-27-2012 09:53 AM in reply to: blair
Mike (not Matt) Rattray
*Pro
sbixler
Message 13 of 23 (4,222 Views)
07-27-2012 10:29 AM in reply to: blair
I'm not sure, either, what Kevin is referring to, but I also confirmed that drawing export to DXF in 2013 works as it has in previous versions.  Blair, I've always been able to export DXF with Model Geometry Only; in fact if I choose to scale to 1:1 in Model Space, Model Geometry Only is forced.
blair
Message 14 of 23 (4,215 Views)
07-27-2012 10:47 AM in reply to: blair
I'll have to look at the 1:1 option, never in all the years (IV4) have I looked at the 1:1 option in the DXF.
Win7-64
Delta Tau Chi ΔΤΧ
Employee
KevinLi-Autodesk
Message 15 of 23 (4,168 Views)
07-30-2012 07:33 PM in reply to: blair
Hi Guys,
I am so sorry that I made a mistake here, Inventor supports to export DRAWING to DXF format via Save As -> Save Copy As -> DXF Files dropdown.
My fault to make you confuse and inconvenience !!!
Kevin Li
Quality Assurance Team
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Distinguished Contributor
amasva
Message 16 of 23 (4,158 Views)
07-31-2012 01:06 AM in reply to: blair
Hi
A little tip. If you hold down "ctrl" and  "shift" and then click new you get a dialog box. If you then choose drawing you get a empty sheet :smileyhappy:
Asle Martin Svastuen
Autodesk Product Design Suite Ulitmate 2012 Sp1 / Vault Collaboration 2012 Sp1
HP EliteBook 8560w
Intel(R)Core(TM) i7 CPU Q 720 @ 2,0GHz 2,0GHz
16GB RAM
Windows 7 X64 SP1
*Pro
sbixler
Message 17 of 23 (4,151 Views)
07-31-2012 05:12 AM in reply to: amasva
How is this different from just clicking on New and choosing drawing?  Does this have anything to do with exporting to DXF?
amasva
Message 18 of 23 (4,144 Views)
07-31-2012 06:17 AM in reply to: blair
Hi
The tip was ment to Blair. Hi posted:
"We do a lot of CNC profile burning and on some shapes we need to Save-As to DWG and then go in and select what we want to export. I guess one could have a IDW template without any border of title block so all we would get is the model."
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
Active Member
BHOOPER84
Message 19 of 23 (3,630 Views)
01-16-2013 03:22 AM in reply to: jletcher
I am having the same problem as mentioned in this thread.
When I try the 'Save copy as' DXF route it does not function. If I click the save button nothing happens and if I click the option button nothing happens either. In 2012 when you click the options button you would have got the option to change the export settings i.e. all sheets etc...
I do have the option to change the file formats via the drop down box in the 'save copy as' dialogue box and dxf etc are listed!
When I right click on the flat pattern in 'Model' there is no button for 'Export' in the list that appears. Therefore I cannot get to the Flat pattern dxf export options prompt as shown in this thread.
Its obvious you should be able to save as a dxf from an inventor idw as the buttons are there they are just not working!
Any advice/help would be greatly appreciated.
Many thanks!
New Member
reklawgb
Message 20 of 23 (2,879 Views)
06-24-2013 07:33 AM in reply to: BHOOPER84
I am having this problem with Autodesk Design Suite Premium. Inventor 2014 will not give me options, and is having problem exporting to autocad dwg. tried a reinstall as it appears to wotk properly on other similar ionstall machines. Does anyone no what may be causing this issue and how to fix.
