Inventor Forum
Inventor 2013: Error Creating Detail Views
6 REPLIES 6
1348 Views, 6 Replies
We have struck a problem this morning, that we are hoping we can resolve quickly or at least get some help with.
We have a conveyor belt profile, which covers a length of 2330 meters and a height of 150 meters. We have a place a elevation view of the profile in an idw file at a scale of 1:2500.
We would normal place detail views on the elevation view to zoom in on key areas of the belt, i.e. drive area etc. In all previous release of inventor had no problem. However Inventor 2013 displays the following error.
Create Profile and Section View: Problems encountered while executing this command.
The specific inputs did not create sweep geometry (faces and.or edges). Try by changing path geometry and/or create the profile on a sketch plane that is perpendicular to the path and contains one of the path vertices.
I have attached the part file and also the idw file that we are using.
Any help on this matter will be greatly appreciated.
Mark
Tags (1)
6 REPLIES 6
rhasell
Mark
I gave it a quick try, sorry, I got the same error, if I get a gap later, I will try again.
I even tried to crop it, hoping that you could place multiple "base views"  alas, that did not work either.
Reg
2024.2
Please Accept as a solution / Kudos
rdyson
Definitely seems to be a bug.
In the mean time, attached is a work around that might work for you
PDSU 2016
in reply to: rdyson
rdyson
Thanks for the work around, I have passed this onto my drafting department and might be what we need to do to get us out of trouble.
Hopefully Autodesk can get a Hotfix out for this soon.
Is it just me or does it seem that Autodesk have completely drop the ball on the 2013 release of Inventor, we have had so many problems with this release.
Mark
Any progress with this one Autodesk?
I am having the same problem and it is causing massive problems. Similar situation with a swept conveyor belt profile, however, the detailed view works on the belt at part level and on a simpler 'mock up' of the belt and an assembly. It only fails on the top level assembly which is a combination of the belt part and other parts/assemblies/weldments.
Found the problem...
The conveyor belt was too big for inventor to handle.
"The maximum size of an Inventor part model (only part) is bounded by a cube of 10000cm X10000cm X 10000cm. When a solid body exceeds the boundary, the modeling commands will behave unpredictably.
For assembly, there is no internal size limit on how big an assembly can be. However, it is restricted by hardware (memory, CPU) and OS (maximum floating number allowed)."
johnson.shiue@autodesk.com
Amended this and everything is working ok for now.
Arindam2012
We are facing the same problem wih our 1350 meter long shuttle head conveyor. so i am assembling the conveyor in many parts.
But I could not understand if Inventor can produce a Elevation of the entire model then why it can not generate a small portion as a detail of of it. If any solution or hotfix is available that will be very much helpful for us.
aub@lntecc.com
Thanks in advance.
Regards;
Arindam
