When I use Autocad if the dimension extension lines are too close I could cause the dimension to be placed on the left or right side as desired. If I selected what I wanted to dimension starting left to right the dimension would be placed on the right side of the extension lines and vice versa going the other way. Is there a way to cause Inventor to do this? I seems like no matter what direction I chose, the dimenion ends up where I don't want it. Typically liner fraction dimenison.
This has bugged me for several releases now. Thanks for any help.
Solved by Curtis_Waguespack. Go to Solution.
Hi cparnell,
There are some tips for this at this link:
http://inventortrenches.blogspot.com/2011/08/drawing-dimensions-left-or-right.html
I hope this helps.
Curtis
Curtis:
Yes that did it. Thank you very much for the help and your link.
